Yes No
Ads
Tom's Hardware > Forum > Graphics & Displays > Nvidia > Help me buy a new graphics card
Forum Graphics & Displays : Nvidia Help me buy a new graphics card
BUDGET RANGE: $150-200
for maya and gaming
OVERCLOCKING:Maybe
SLI OR CROSSFIRE: No
currently not using a graphics card
building a new pc so no compatibility problems
Reply to mach_06
Which PSU are you using?
------------------------------ Core i7 2600k, Asus P8Z68 Deluxe, 16GB Patriot DDR3, 2TB HD , SLI GTX 460 1GB, XFX 750W BE, 3D Vision, CM 690 II Advanced
Reply to vitornob
easier if you list down your system spec first. or did you still in selecting all your parts stage?
------------------------------ Core i5 2500K @ stock / Stock Cooler / Asus P8Z77-V LX / 8GB Kingston HyperX Genesis DDR3 1600Mhz (9-9-9-27) / Samsung Spinpoint 750GB / Asus ENGTX460 1GB DirectCu TOP / Xigmatek NRP-MC702 (700W) / CM 690 II Advance (USB 3.0)
Reply to renz496
for maya and gaming
OVERCLOCKING:Maybe
Hey,
First off, You chose to build a new pc! Excellent Decision!
Maya, huh.. Sounds like you'll be doing some intensive 3d Animation. Need Hyper Threading..
Heres a list of basic suggested specs:
Processor: Intel Core i7 2600K ~$320
Gfx Card: MSI Twin Frozr II Gtx 560-TI ~ $245
Ram: 8GB 1600Mhz Corsair ~ $50
PSU: 650W CoolerMaster ~ $75
Hope this guides you well enough.
Cya.
Reply to Rockstar_7
doesn't matter... i'm building a new comp so power supply can be arranged accordingly
Reply to mach_06
I'm selecting the parts... so gpu comes first... the rest has to be chosen to accommodate the graphics card.. u can suggest me the whole system config if u want!
Reply to mach_06
now that u people have recommended me hd6850 and gtx 560ti... which one do u think is better? i have never used amd gpu so again i need some advice!
Reply to mach_06
There are 2185 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
Will this video card work on my PC..
By looniam, 4 hours ago:
no need for power connections and your PSU is ok to go with it...
Best offers
Top experts
