Power supply problem?
  • Power Supplies
  • Cases
  • Power
  • Components
Last response: in Components
May 6, 2012 9:11:01 AM
Hi community!
I have been having strange cases of my pc not turning on immediately after pushing the power button, same for the power button on the mainboard so no I don't think the power button on the case is the problem here. The thing is I have been having this for a few days now, have to repeatedly push the power button until the pc turns on as if it was purely random. Checked the LEDs on the mobo and it seems to be supplied with power since the LEDs for power and reset button are on. Can I assume that its not a fried motherboard since when turned on the rig works just fine? It almost seems as if the power supply unit is doing a number on me here. Any help, suggestions for the source of my problem is much appreciated.
More about : power supply problem
May 6, 2012 3:14:39 PM
Do you have another psu you can try it with?
May 6, 2012 3:58:01 PM
unfortunately no I don't have a spare one at my hands, and if it is any help the onboard power switch is always flashing red even when I manage to power the pc up, just thought I mention that since it seems strange
May 6, 2012 4:03:45 PM
it sounds that there isnt a signal going to the psu to start the pc. try looking at the connectors on the motherboard to see if there is a proper connection.
Is there only power to your mobo or is the fans also coming on?
If so then it might be the mobo thats fried if not, the power supply
May 6, 2012 4:53:02 PM
nope, neither the fans nor anything else powers up, I am going to check the connectors ans see if theres something wrong thx for the advice
May 6, 2012 6:40:39 PM
if its not the conectors then i think it must be the psu. good luck
May 7, 2012 10:43:56 AM
wow man thanks a lot for the advice, installed a new corsair 850w psu and everything runs as it should again, thanks again :)
May 8, 2012 1:54:57 PM
nice there you go with a healthy pc.
