So, the case Im looking at, "cooler master storm trooper" and the 932 Advanced..
Now, the ST has 2 side fans, where as the 932A can hold 4... (Im probably going to go with the Storm Trooper)
Anywho, as some of you know, having fans on the side is great for cooling, can can be a pain when wanting a clean cable mang. is a priority... and also, when taking off the side of the case, you have wires coming out that have to be unplugged... I wonder if anyone had ideas or stuff they've done that Im not thinking of that's a good way to mount these fans up without having 2-4 fan wires just hanging in the middle of your case?
Maybe get some long 3pin extension cables and run them in the top or bottom and then tuck them away? Seems like unplugging them would be a pain then?
Any ideas?
Any ideas?
