Ok so here it goes, i plan on building my first system and id appreciate any input from folks on some of the parts that iam considering for my build, any advice as far as parts that might be better or more compatible etc.. Also i dont have a complete build as thats what iam gradually working towards. Budget for the build isnt to much of an issue athough id like to try and keep it below $1500, also primary use will be for gaming on and offline, id like to be able to run dual screens, and dont plan on overclocking but would like to have the option to once ive read up on how stuff works and make a decision atfre becoming informed on stuff and also iam considering giving myself the option to expand to running SLI in the future.
Ok so here what iam looking at
ASUS Maximus IV Gene-Z/GEN3 -Motherboard
EVGA SuperClocked GeForce GTX 560 Ti (Fermi) (might go for a higher card and or something with 2GB's of mem maybe) -GPU
Model- 01G-P3-1567-KR
Intel Core i5-2500K Sandy Bridge -CPU
G.SKILL Ripjaws X Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600
(PC3 12800) -RAM
Model- F3-12800CL8D-8GBXM or N82E16820231428 (these are the two i was looking at)
Western Digital Caviar Black 1.5TB 7200 RPM 64MB Cache SATA
6.0Gb/s 3.5" - HDD
Model- WD1502FAEX
Intel 510 Series (Elm Crest) 2.5" 120GB SATA III MLC -SSD
Model- SSDSC2MH120A2K5
ThermalTake 750W -PSU
Model- TPG-750M
Thanks for any and all help
(PC3 12800) -RAM
6.0Gb/s 3.5" - HDD
Model- WD1502FAEX
Model- TPG-750M
