Archived from groups: rec.photo.digital (
More info?)
"Justin Thyme" <pleasedontspamme@nowhere.com> wrote in message
news:12_he.302$q33.4289@nnrp1.ozemail.com.au...
> <grevillea@ozemail.com.au> wrote in message
> news:1116232293.445981.30530@f14g2000cwb.googlegroups.com...
>> Pentax ist ds---camera repaired for autofocus problem---reverted to
>> closest focus most of the time.
>> Now infinity seems to be out---infinity is slightly off the far right
>> turn stop---tested using the landscape mode and autofocus and confirmed
>> with manual focus. expected infinity to be as far to the right as I
>> could go.
>> Is this a problem? does it need to go back for more repairs (the last
>> set took 4 weeks!!!)?
> It is normal for lenses to focus slightly beyond infinity (if that makes
> sense). If the lens was designed so that infinity fcous was at it's
> extreme position of operation, you would find situations where you
> wouldn't be able to achieve infinity focus. For example temperature
> changes or even a bit of crud on the lens mount would be sufficient to
> stop the lens focussing to infinity. Therefore they design the lens to
> focus a little beyond infinity so that there is enough provision left in
> it to allow for temp changes etc.
>> anyone else have this problem?
> it ain't a problem - every single SLR lens is designed like this, if it
> wasn't then you would have problems.
I've always heard this and it does make sense, but all my older Pentax and
Nikkors would stop right at infinity. These lenses seemed to be much finer
quality (and very sharp) optical instruments with tight tolerances. Now
everything has lots of plastics in the design and some of the lenses feel
somewhat loose. I'd say the extra focus adjustment past infinity is
allowance for slop in the design and possible the extra coefficient of
thermal expansion of plastics as compared to metals.
John
