80mm Fans for front of case?
  • Cases
  • LED Monitor
  • Components
  • Product
Last response: in Components
May 7, 2012 1:40:31 AM
I need 2 80mm fans for the front of my case... could someone suggest good fans for a low price?? (doesnt need to be that quiet, but not too loud. LED not necessary but if its cheap :D  anyways, how should i set up my push pull system??
i have one on the back pushing air out and one on the side pushing air in. should i make the 2 front fans intake?
this is my case: http://www.newegg.com/Product/Product.aspx?item=N82E168...
my build is a 970xtreme3 mobo with a radeon 5770, amd fx 4100 @ 3.6ghz and 8 gb ram
More about : 80mm fans front case
May 7, 2012 1:54:10 AM
http://www.newegg.com/Product/Product.aspx?Item=N82E168... pushes a lot of air. one of the highest CFM outputs of any 80mm fan i could find. Can get a bit noisy at 100% though. Still, since your case does not have a lot of cooling, i thought putting the most you could get into it would make the biggest difference for you.
m
l
May 7, 2012 1:59:06 AM
Both front fans should be intakes.
m
l
