Thermal Paste Removal/Installation Guide
Power Supplies
- Heatsinks
- Thermal Compound
Processors
Components
Last response: in Components
Today I will be teaching you how to remove thermal paste from your heatsink and processor. Usually people will replace their paste 6-12 months, as paste dries out and temperatures rise!
What you will need:
Isopropyl Alcohol:
At least 70% is needed, 90% if possible. This can be purchased from almost every pharmacy and supermarket, mine is from Walgreens.
This is used to remove the paste from the processor and cooler, be careful not to spill any!
Paper Towels:
These are dabbed in the Alcohol and rubbed on the cooler/processor to remove the Old Paste!
Thermal Paste:
This is to increase the thermal conductivity between the processor and heatsink by filling in microscopic holes between that are on the heatsink and processor.
Whenever a cooler is removed from a processor, new paste needs to be applied. I will be using Arcrtic Silver 5 for todays cooler installation.
Heatsink:
This can be your previous one, or a new one! I will be using the Cooler Master Hyper 212 EVO
Cooler Master Hyper 212 EVO Review/Performance: http://www.overclockersclub.com/reviews/cm_hyper212_evo...
For those of you wondering, I am using an Aerocool Shark 120mm Fan on the 212 EVO with the stock Fan that comes with the EVO as well in a push pull configuration!
Aerocool Shark 120mm Fan Performance Compared to Other 120mm Fans:![]()
The review uses an AMD Black Edition 965 overclocked to 3.9ghz with a Noctua NH-D14.
What you will need:
Isopropyl Alcohol:
Paper Towels:
Thermal Paste:
Heatsink:
More about : thermal paste removal installation guide
Step One: Removing The Paste From The Heatsink.
Once you have removed your heatsink from your system, open up your alcohol and place a paper towel on top like so:
Then, quickly flip the bottle of alcohol over (paper on top) to get some alcohol onto your paper towel like so:
Now we can begin by placing the part of the paper towel where alcohol is on to the base of the heatsink, and start rubbing back in forth like so:
After you rub for a few seconds, you will notice that your paper towels have taken off some of the paste:
Repeat this process until your heatsink is nice and shiny with no traces of paste on it!:
Step Two: Removing Paste from the Processor.
Once you have finished cleaning the heatsink, you are ready to clean the processor!
Apply some rubbing alcohol onto some paper towels, such as in step one:
Then begin rubbing like you did for the heatsink:
As you can see, the thermal paste is completely removed from our i7-2600k and everything is looking good for the next step:
- Thermal Paste Removal/Installation Guide - Forum
- Looking for a Thermal paste application guide - Tech Support
- Guide for applying thermal paste to a 3930k - Forum
- Do I really need to buy thermal paste for new cpu ? - Tech Support
- Stock vs. Aftermarket Thermal Paste | What should I use ? - Tech Support
Step Three: Application of New paste.
Once you have removed the old paste from both your processor and heatsink, you are ready to apply your new thermal paste!
Since we are using Arctic Silver 5, the application will be slightly different. Unlike other pastes, Arctic Silver 5 requires us to apply the paste in a vertical line method on specific processors, in this case we are using the Intel Core i7-2600k.
For a list of processors Arctic Silver specifies, click these links:
Intel: http://www.arcticsilver.com/intel_application_method.ht...
AMD: http://www.arcticsilver.com/amd_application_method.html...
Arctic Silver 5 Performance Compared to Other Compounds:
Line Method:
Right after applying paste you should install your new cooler! Personally, I use the weight of my cooler to spread the paste. However, you can spread it around to a thin layer with things such as an old credit card.
Step Four: Installation of New/Old Cooler.
Now we have installed the Hyper 212 EVO, we are good to go!
Thermal paste and cooling fan temperature results belong to 4ryan6.
FAQ
How long can I run my system before I need to reapply thermal paste?
Line Method:
FAQ
ddan49
May 10, 2012 12:13:54 PM
csp5038
May 11, 2012 12:40:48 AM
ddan49
May 11, 2012 1:07:15 AM
Dovetonsils
May 11, 2012 6:13:49 AM
It's a good guide but it's kind of incomplete as Arctic Silver only recommends the line method for some CPUs.
You also have to take in account that is ONLY correct for Arctic Silver as well. Different pastes have different viscosities and spread differently. What works for Arctic Silver will not be correct for the very thick IC Diamond.
http://www.innovationcooling.com/applicationinstruction...
Yuka
May 19, 2012 6:16:27 AM
Quote:
personally I think you used too much paste...but very good 'stickie'.
well deserving.
I agree with mal, here.
That's a lot of paste, amuffin.
I apply just a "mid siezed" drop in the middle then start spreading the paste with something like a ruler (straight side, sturdy) over the CPU plate (looking for no dirt or something that might fall over it) leaving the paste as thin as possible and then put the HSF on top.
By far, that's the best method I found to keep the temps low (and save AS5 for future builds, lol).
Cheers!
digitalhardware
May 19, 2012 3:32:39 PM
Yuka
May 19, 2012 5:23:14 PM
digitalhardware
May 19, 2012 5:45:15 PM
smrnf92
May 22, 2012 4:11:58 AM
Appsch909
May 26, 2012 8:21:52 AM
anort3 said:
It's a good guide but it's kind of incomplete as Arctic Silver only recommends the line method for some CPUs.http://www.arcticsilver.com/intel_application_method.ht...
Affirmative!
amuffin said:
It was my first time applying AS5 so I didn't really know
I suggest to make this guide thorough you need to do extensive trial and error test fitting to see how each type of TIM, is going to spread, if it's your first time applying something do it numerous times, inspecting the footprint to see exactly what's going on with the application method you're using.
The original CMH212+ actually needed some pre-application TIM filling on the heat sinks base to fill in between the pipes and aluminum base plate, various different types of coolers with different base finishes require different types of applications and pressures, some are finished to a mirror finish and they're in a class by themselves.
What makes a great sticky is use the advice and criticism to edit it and make it better, do not get discouraged by the criticism, and regarding some of it consider the source and what they may have added to THGF themselves, or are they just sitting on the sidelines doing nothing.
I personally take great pride in your efforts to step up and do something here to help others, and even this can be a stepping stone to a masterful sticky, you take what you learn and use it for your own purposes, you will never please everyone!
Galego
May 31, 2012 5:08:02 PM
Can I use any kind of thermal paste or there's an specific type for each processor?
http://img171.imageshack.us/img171/4406/59010998.jpg
http://i130.photobucket.com/albums/p250/4ryan6/TRAC2.png
Line Method:
http://img40.imageshack.us/img40/5923/29567930.jpg
http://img708.imageshack.us/img708/5995/27468507.jpg
amuffin said:
Step Three: Application of New paste.Once you have removed the old paste from both your processor and heatsink, you are ready to apply your new thermal paste!
Line Method:
Great guide but paper towels? No. Coffee filters are the way to go.
Anything but liquid metal TIM would work. Liquid metal will just destroy your aluminum HSF and the top of your CPU (along with its warranty)
Galego said:
Can I use any kind of thermal paste or there's an specific type for each processor?Anything but liquid metal TIM would work. Liquid metal will just destroy your aluminum HSF and the top of your CPU (along with its warranty)
I use kitchen wipes myself. They don't leave fibres and are big enough to have plenty of surface area for several iterations of the cleaning process. I usually go over each surface with a new application of alcohol three times (possibly more for IC Diamond because it's so thick). It's surprising how much residual paste can cover each surface even though it looks clean.
Yuka
June 11, 2012 4:02:46 PM
Quote:
For how much time we have to replace it ?What do you mean by that?
Once you apply the paste, you have time until dirt gets on the paste or something like that. And once applied, it should last a good 10 years before even worrying, if not more. It really depends on the compound used, but most should last a long time.
Cheers!
ddan49
June 12, 2012 9:06:45 PM
Common questions (from an actual dummy
1) Why replace TIM?
2) How often should you replace TIM?
3) What's some good TIM?
4) What are some other types of TIM? (There's paste and like... a liquid metal)
5) Is there any difference on the application methods? (Lines vs one big glob)
6) What are some common mistakes?
That should get you started!
):1) Why replace TIM?
Ladamyre
June 16, 2012 3:47:07 AM
Maybe some pastes dry out in 6 -12 months but I've pulled coolers off of my CPU's after years of usage and found the stuff still sticky, still working. Seems to me if the paste is such poor quality that it dries out that quickly, I'd quit using it.
Then again, there's a company that's selling some sort of plastic/metal type material that needs to be 'burned in', that is to say melted into the interface after it's installed and is supposed to be better than any paste and permanent to boot. I plan to use it on my next build.
I won't name it, don't want to be accused of spamming, but I will say it has a colorful name. Don't want anybody to get the 'blues' over me promoting a product here.
ddan49
June 16, 2012 1:37:40 PM
AntiZig
June 20, 2012 3:44:26 PM
Ladamyre
June 21, 2012 5:50:31 AM
ddan49 said:
Ah... Ladamyre? This entire forum is built on recommending products
For example, recommending an i5-2500k is perfectly fine... and many people recommend AC5 for TIM. I think you'd only risk getting banned if you did something like nonstop promote an irrelevant product.
)Don't hold them to any claim on my part, but the more I think about the stuff and how it's applied the more sense it makes. Then again, I'm one of those overclocking cowboys that'll spend $20 just to get two degrees cooler and thus get 20 more MHZ out of the CPU. When you think about it, that's less than a penny per KHZ! Whoopee!
Yuka
June 21, 2012 11:11:54 PM
ddan49
June 22, 2012 12:49:59 AM
AntiZig
June 22, 2012 3:18:35 AM
nice find, the only problem i find with it, it has to be mounted without thermal paste at 1/1000th of an inch above surface. Practically that's impossible to achieve in non-lab environment.
Also, it will collect dust and that monstrosity spinning at 2k rpm will make noise, looking at the form it will chop the air so much
Yuka said:
Relevant link for today:http://gizmodo.com/5920224/brilliant-spinning-heatsink-...
Cheers! xD
AntiZig
June 22, 2012 12:43:21 PM
Ladamyre
June 22, 2012 6:50:11 PM
I'll believe it when Tom does a review.
Oh, I get the idea about the 'air bearing' and no, it won't take a lab environment to make that reliable, your cars engine does that using oil.
What I don't believe is the claim "X times more efficient than some air coolers".
Hell my 6 year old Zalman is 30 times more efficient than some air coolers too.
That claim is what we used to call 'dooky', don't mean sh... uh... cra... can we say crap?
Jonathanese
July 3, 2012 8:38:53 PM
I wonder if that red stuff can be used as TIM?
Anyway, even with systems with heat spreaders, wouldn't there still be an advantage to spreading the thermal paste over the simple line method? It seems like no matter the TIM, the line method would still place too much in the middle, and not take advantage of all that extra real-estate for transfer. I figure, if you go ahead and spread it out, you only have as much TIM as you need in the center, but also allow better heat "bandwidth" so-to-speak. I say this, because I'm about to get a direct touch heatpipe cooler, and if I only use the line method, I'm making decent contact with only one of the three pipes. But in spreading it, I take advantage of every square-inch of the cooler and IHS.
- SolvedIs this Thermal Paste good? solution
- SolvedHelp with HD 5770 Thermal Paste solution
- Solvedthermal paste vs thermal pads/tape on the cpu/block. what are the advantages and disadvantages? solution
- SolvedNeed help to decide the amount of thermal paste solution
- SolvedMake-up wipes for removing thermal paste? solution
- SolvedWhat will happen if we don't have Thermal Paste? solution
- SolvedDid i mess up the thermal paste? solution
- SolvedCan i remove thermal paste without any alcohol? How? solution
- SolvedReapply thermal paste on new CPU attached a week before? solution
- SolvedShould I spread thermal paste? yes or no? solution
- Solveddose g2030 require thermal paste solution
- Solvedapllied new thermal paste to cpu now nothing will respond solution
- SolvedDo I need to buy a seperate thermal paste? solution
- SolvedDo you need thermal paste? solution
- SolvedCorsair H105 Thermal Paste Quality? solution
- More resources
Read discussions in other Components categories
