Thermal Paste Removal/Installation Guide - Page 4
Power Supplies
- Heatsinks
- Thermal Compound
Processors
Components
Last response: in Components
Ken Su
July 26, 2013 7:06:20 AM
thasan1 said:
Ken Su said:
Right after I apply the thermal compund on the heatsink and place it on top of the CPU. Can I take it back out or will that damage anything. Because I put the heatsink on and realize that the bracket doesn't match the screw so I take it out and wipe the thermal compound off the CPU and heatsinker. Is that OK?
And what happen if I touch some metal parts at the bottom of the motherboard. Will that shock the motherboard and other parts on the motherboard already?
if you take out the heatsink after applying the paste then it won't damage anything. but if you put it back in the CPU without reapplying the paste your CPU will probably overheat due to poor thermal conductivity as there will air bubbles between the paste and heatsink plate.
I took out the heatsink while there is some thermal compound still on the heatsink and CPU. I wipe it off with tissue paper and reapply it. Will that be OK? It was kind of hard to pull it off maybe cuz of the thermal compound.
Also it is OK to touch some metal parts of the motherboard at the bottom when lifting it up?
Ken Su
July 26, 2013 8:21:51 AM
thasan1 said:
@Ken Su did you clean the heatsink with isoporpyl alcohol? and also the mobo thing won't be a problem. though you should touch a metal surface before touching any thing in the CPU or ram just to keep safe.I haven't clean it yet but I will use some kind of alcohol to wipe the heatsink and CPU.
If the mobo is broken and I power it on. Will everything else on the mono also be broken than?
- Thermal Paste Removal/Installation Guide - Forum
- Looking for a Thermal paste application guide - Tech Support
- Guide for applying thermal paste to a 3930k - Forum
- Remove and replace heatsink - extra thermal paste needed? - Tech Support
- I recently purchased an i7 4770K. There was no thermal paste included. Is it pre-applied? - Tech Support
thebluephilip
August 21, 2013 4:09:37 AM
Sajeel Niazi
August 24, 2013 10:56:02 AM
Kamikazi2142
August 30, 2013 5:05:31 AM
MiDNiGhT2903 said:
Can I use methylated spirit 99%?Can't get hold of any isopropyl alcohol.
define "Metholated Spirit" is it an alcohol based? or is it an acetone, Acetone will erode the nickel plating and the copper heat pipes and or copper anything. I recommend if you DO NOT have alcohol, to just use a clean dry cloth or rag, be sure no debris is left from either the old paste or the cloth, and you will be fine.
Naer
September 2, 2013 6:36:13 PM
cerefo
September 19, 2013 2:09:07 AM
I will look Noob by asking this question but I want to know that:
1) Are there fans in which I don't need to apply thermal paste?
2) I am not sure but does thermal paste comes with cooler or with the processor?
3) What is the exact name of the component(hardware; that big machine; looks like a fan) that you are putting over your processor?
Kamikazi2142
October 20, 2013 7:52:24 AM
cerefo said:
I will look Noob by asking this question but I want to know that: 1) Are there fans in which I don't need to apply thermal paste?
1) you do not apply thermal paste to "Fans"
2) Many aftermarket coolers and stock heatsinks come with thermal paste, some have it pre applied.
3) that would be called a CPU Heatsink
if you do not know the name of the device, you should not be worrying about whether or not it has paste pre applied, you should be searching google for wiki's and youtubes to walk you through until you have enough of an understanding on the basics and then you build up the courage to put yourself to the test. Be careful, be very careful, Google and Bing every step of the way before you open your case.
Kamikazi2142
January 11, 2014 6:00:28 AM
Naer said:
What are ways in finding out when you need to do this? CPU temp software?CPU temp software like "CoreTemp" running in the background will show you the hottest your CPU reaches overall, and as it gets higher it will change the highest accordingly so you don't get misleading results from alt tabbing out of a video game to check your temperatures, if you have ROG Connect, a feature on most newer ASUS ROG motherboards you can monitor your temperatures actively via laptop. Monitoring your thermal increase over time should be required for higher end CPU's on STOCK cooling solutions, a weekly ritual on aftermarket heatpipe coolers, and a once a month hobby for closed loop liquid cooling and custom loop water cooling, and for those fancy enthusiasts with Phase Shift Cooling (probably called Phase Change) you may just need to check up on your pressure levels once every 2 to 3 months.
Watch your temp, if it sky rockets from playing a game, you need a better cooler. If over time you notice it getting hotter and hotter, remember, 65C is game load average temps, not idle temps, you can suffer 10C to 20C increase over time, but change the paste at 30C increase.
Osoclocker69
January 13, 2014 7:10:56 PM
Kamikazi2142
January 13, 2014 8:33:25 PM
Osoclocker69 said:
that is too much thermal paste to be out on the cpu!as true that may be for any other perfectly flat HS, the CoolerMaster Hyper 212 Plus has grooves along the bottom and without sufficient thermal paste, they will prevent proper bloom of thermal paste upon application of HS. How do i know this? I own a Hyper 212 Plus, i had to pre apply it to the HS using a squeegee to wipe off the excess so that the paste on the CPU would spread evenly.
Osoclocker69
January 14, 2014 3:23:40 AM
Osoclocker69
January 22, 2014 6:15:34 AM
Kamikazi2142 said:
I find cpu coolers like the one i recently bought (Deepcool Gammaxx 300) because it comes with pre-applied thermal paste and it is very nicely spread. A very even layer. And so far the top temp I get is 50 C while running a torture test in Prime95 (at stock cpu clocks)
Kamikazi2142
January 23, 2014 2:22:06 PM
Osoclocker69 said:
here are some pros and cons
Pre applied thermal compound:.
Pro:
Pre applied thermal conductivity
no guess work or messy cleanup
Con:
risk for air pockets reducing overall thermal conductivity
faster dry out rate reducing overall life span of thermal bond
thicker pad of thermal compound
DIY thermal paste:
Pro:
no air pockets
even spread
longer life
thinner layer of thermal paste
Con:
some heatsinks have grooves reducing overall spread
readings can be misleading before thermal paste cures
Generally it is best to apply your own thermal paste and scrub off the pre applied compound, if you are unsure about application there are plenty of tutorials and directions on how to apply thermal paste with many different methods.
This may better help you understand what happens with thermal paste.
Osoclocker69
January 23, 2014 5:23:33 PM
Osoclocker69
January 23, 2014 5:29:00 PM
Pro:
Con:
DIY thermal paste:
Pro:
no air pockets
even spread
longer life
Con:
Hey I was wondering how you unparked the cores? And also do you get any BSOD? Because most people i know that unparked their cores get BSOD a few times
Kamikazi2142
January 23, 2014 10:03:15 PM
no BSOD for me, i did get some from my RAID setup but that was because the installer installed the wrong drivers, installed an XP 64 driver instead of the correct Win7 64 driver.
i hear there are two ways to unpark, there is the direct through registry, and a program, i hear the program is recommended. LINKED HERE is the better way to turn it on or off (idk why you would want it off)
I had some programs stop working a few times upon first launch with cores unparked, but nothing serious.
dddingggiii
February 4, 2014 3:09:30 AM
Yep ... just don't slosh the stuff about all over the place.
ethanol / methanol / methylated spirit... but do not stoop to using petrol or other mixed longer chain hydrocarbon based solvents or fuels as they leave residue which interacts with the thermal grease.
I am also not keen on acetone / aldehydes / esthers / ketones.
Drill baby drill !!!
dddingggiii
February 4, 2014 4:17:09 AM
Osoclocker69
February 5, 2014 1:07:48 AM
XCalinX
March 7, 2014 8:56:37 AM
Osoclocker69
March 7, 2014 6:48:40 PM
XCalinX
March 8, 2014 1:15:47 AM
Osoclocker69
March 8, 2014 4:22:55 AM
XCalinX
March 8, 2014 11:54:06 PM
Osoclocker69
March 11, 2014 12:48:58 AM
XCalinX
March 11, 2014 11:43:23 AM
Osoclocker69
March 11, 2014 11:59:48 PM
panos1
March 17, 2014 5:28:08 AM
Here is a video on how to apply thermal paste on Apple iMac video board
http://www.youtube.com/watch?v=e9v5MDivZfc
Santu Lama
April 2, 2014 2:57:15 PM
Yuka said:
Relevant link for today:http://gizmodo.com/5920224/brilliant-spinning-heatsink-...
Cheers! xD
https://www.youtube.com/watch?v=JWQZNXEKkaU
I found thi link too for the heatsink you were talking about.
Dkfan241
April 30, 2014 7:08:30 PM
Thx for help! I'm so stupid, I thought the thermal paste would make the cpu cooler stuck to the cpu >_<, I'm kinda a noob but I know the basics like graphics cards, CPUs , the differnce of what CPUs go on what motherboards like 1150 and 2011 boards, ssds are faster then a HHd, types power supplys, and what some of the best cpu coolers are. Now I just need to learn how to over clock the fudge out out of graphics cards and CPUs! Again Thx for the help!
Kamikazi2142
May 27, 2014 4:57:46 PM
Osoclocker69 said:
XCalinX said:
But I get ok tempsGetting "Ok temps" doesn't mean the will be "Ok" for every other CPU, specially the ones with overclock.
And alcohol is not "sh*tty", it actually helps cleaning quite a lot.
not to mention also leaving behind debris from the napkins all over the surface of the CPU and where ever else it was near, Napkins are also static generators.
- 1
- 2
- 3
- 4 / 4
- SolvedThermal Paste on CPU HELP! solution
- SolvedVERY IMPORTANT! Thermal Paste?! solution
- SolvedDo I really need to buy thermal paste for new cpu ? solution
- SolvedStock vs. Aftermarket Thermal Paste | What should I use ? solution
- SolvedIs this Thermal Paste good? solution
- SolvedHelp with HD 5770 Thermal Paste solution
- Solvedthermal paste vs thermal pads/tape on the cpu/block. what are the advantages and disadvantages? solution
- SolvedNeed help to decide the amount of thermal paste solution
- SolvedMake-up wipes for removing thermal paste? solution
- SolvedWhat will happen if we don't have Thermal Paste? solution
- SolvedDid i mess up the thermal paste? solution
- SolvedCan i remove thermal paste without any alcohol? How? solution
- SolvedReapply thermal paste on new CPU attached a week before? solution
- SolvedShould I spread thermal paste? yes or no? solution
- Solveddose g2030 require thermal paste solution
- More resources
Read discussions in other Components categories
