Power supply help
  • Power Supplies
  • Power
  • Components
Last response: in Components
May 7, 2012 10:30:19 AM
Please help me with this....
i don't know which power supply to pick... and since the choices are limited.. here they are
Huntkey GreenPower 500W
Acbel R8 Power II 550W
Thanks guys :)
More about : power supply
a c 122 ) Power supply
May 7, 2012 10:33:19 AM
I wouldn't buy either of those what is your spending limit
m
l
May 7, 2012 10:37:27 AM
i have a very limited budget
m
l
a b ) Power supply
May 7, 2012 11:26:41 AM
I'd really recommend getting a reputable power supply. power supplies are one of the things you DON'T want to skimp on. A decent branded 450W+ would probably give better power than those you listed. Can you afford an XFX core 450W? they seem to be great cheap (but reliable) PSUs.
what are the system specs and what is your budget?
m
l
