Help with new case
Niels P
i have to get a new case but i cant deside between the cm storm trooper and cooler master haf x what do you think?
Chunkinator
23
If you can fit everything into a mid tower and have enough cash for a full tower, I would recommend the Corsair Graphite Series 600T - A mid tower case with superb airflow.
I'm using a Graphite 600T White here, 'tis awesome.
There is not much difference between the two as both are full tower cases and it looks like its all about the inside of the cases with each one having different fan arrangements. I have the Half-X and I think it is just a bit larger but not so as you would notice and it has a few more options inside.
So I would go with the Half-X.
