Coloured Modular Cable Kits by Corsair??
  • Power Supplies
  • Corsair
  • Cable
  • Components
Last response: in Components
May 7, 2012 3:25:10 PM
I've seen loads of you tube videos, reviews and even them on the main corsair website but I can't for the life of me find any of these for sale in the UK, does anyone know where I might be able to get a set??
More about : coloured modular cable kits corsair
a c 104 ) Power supply
May 7, 2012 4:28:38 PM
It would depend on the Psu you have, and the connections from that
Moto
May 7, 2012 4:32:46 PM
I have an AX850, so that's why the Corsair kit seemed like a perfect match
May 7, 2012 5:10:55 PM
If the connectors for the Psu end are the same as the other end then yes, the extensions will fit straight in, if they differ though you would have to use the extensions from the original cables, making it longer ofc
Moto
May 7, 2012 5:55:36 PM
Ok thanks for that, guess these are not what I'm looking for then and I will try elsewhere thank you.
May 7, 2012 6:00:14 PM
No problem man, if I find them here I'll repost for you
Moto
