New Graphic Card, Need Help
  • Power Supplies
  • Graphics Cards
  • Components
Last response: in Components
May 8, 2012 12:06:45 AM
I just bought a Radeon HD 4870 and my PSU has only one PCIE x6 connector
This is my PSU :
Inter-Tech Energon 550W
1 x 6pin PCIE
4 x SATA
4 x Molex
1 x Floppy
1 x 4+4pin EPS12V
Rail:
Quad rail (18A/18A/18A/18A)
I know I need an adapter to get one more 6pin PCIE, but my thing is that I've seen that there are single molex and dual molex to 6x pin PCIE, and a friend of mine gave me a SINGLE molex to 6x pin PCIE.
Will it work with a single molex to 6x pin PCIE or I need a dual molex to 6x pin PCIE for my graphic card to work ?
Thanks
More about : graphic card
a b ) Power supply
May 8, 2012 1:44:32 AM
Hello !
This is what AMD recommends for the HD 4870: "500 Watt or greater power supply with two 75W 6-pin PCI Express® power connectors recommended (600 Watt and four 6-pin connectors for ATI CrossFireX™ technology in dual mode) "
Having that in mind, the single-molex to PCIe 6x connector would need to draw a maximum of 6.25 amps (75W / 12V). If the rail it will be drawing power from is not close to reaching 18A, then you have nothing to fear.
However, if your 4 molex connectors are all on the same rail, and that 3 of them are used and draw a lot of power, then you might have a problem and exceed the 18A limit.
I hope that answered your question,
al360ex
May 8, 2012 1:54:34 AM
al360ex said:
Hello !
al360ex
I have no optic units, only one HDD, so, only 2 molex connectors will be in use.
a b ) Power supply
May 8, 2012 2:01:29 AM
Then go ahead with the single-molex. You have nothing to worry about.
a b U Graphics card
May 8, 2012 2:27:26 AM
Or you can get a better PSU. get a decent one for 50 bucks.
