Hi there,
This is my first post on the forums and I was just looking for opinions/advice on an initial spec I've put together for a new system that will be mainly used for After Effects CS 5.5, Cinema 4d r12 and Premiere CS 5.5.
I'm looking to keep the system around £1500-£2000.
Spec:
Processor (CPU) Intel® Core™i7 Six Core Processor i7-3930K (3.2GHz) 12MB Cache
Motherboard ASUS® P9X79: INTEL® SOCKET LG2011
Memory (RAM) 32GB SAMSUNG QUAD-DDR3 1333MHz (8 X 4GB)
Graphics Card 1.5GB NVIDIA GEFORCE GTX 580 - 2 DVI, HDMI, DP - 3D Vision Ready
Memory - 1 st Hard Disk 80GB INTEL® 320 SERIES SSD, SATA 3 Gb/s (upto 270MB/sR | 90MB/sW)
2 nd Hard Disk 1TB SATA-II 3-Gb/s HARD DRIVE WITH 32MB CACHE (7,200rpm)
3 rd Hard Disk 1TB SATA-II 3-Gb/s HARD DRIVE WITH 32MB CACHE (7,200rpm)
(* SSD drive as a boot disk for windows and the two other hard drives, one for source to read from and one for exports to write to?)
DVD/BLU-RAY Drive 24x DUAL LAYER DVD WRITER ±R/±RW/RAM
Memory Card Reader INTERNAL 52 IN 1 CARD READER (XD, MS, CF, SD, etc) + 1 x USB 2.0 PORT
Power Supply CORSAIR 650W ENTHUSIAST SERIES™ TX650 V2-80 PLUS® BRONZE
Processor Cooling INTEL SOCKET LGA2011 STANDARD CPU COOLER
Sound Card ONBOARD 8 CHANNEL (7.1) HIGH DEF AUDIO (AS STANDARD)
Network Facilities 10/100/1000 GIGABIT LAN PORT - AS STANDARD ON ALL PCs
USB Options 6 x USB 2.0 PORTS @ BACK PANEL (MIN 2 FRONT PORTS) AS STANDARD
(** better to get USB 3.0?)
Operating System Genuine Windows 7 Professional 64 Bit
I've put together this spec from looking through forums, etc, but any advice would be greatly appreciated.
Thanks very much
Andy
Spec:
Thanks very much
Andy
