Game recording system. ($500 to $600) would like some help.
Approximate Purchase Date: 2/4 weeks
Budget Range: 500 to 600 (Australian Dollars)
System Usage from Most to Least Important: Gaming, Recording,Encoding 1080p video, capturing xbox 360 gameplay.
Parts Not Required: monitor. (Samsung Syncmaster sa350 24inch)
Preferred Website(s) for Parts:None.
Country: Australia.
Parts Preferences: Nvidia
Overclocking: No
SLI or Crossfire: if Nescessary
Monitor Resolution: 1080p
Additional Comments: Hey guys, Could you please help me make system that is upgradeable and will last 2 or so years.
5 answers Last reply
More about game recording system help
  1. I already own Win7 pro 64bit.
    monitor has HDM, D-sub and DVI i think.
  2. if youre going to use fraps, a solid cpu is needed, and a second fraps only hard drive is recommended. so, by your budget, the cpu and a second quality hdd )with good sequeltial write speeds) would be my priority, however, this may be tough. have you looked into buying used parts from respectable forum areas? or even ebay? this will stretch your dollar and afford you decent parts for up to %50 off. (i just got a v1.1 msi BB xpower bnib for 135 on ebay).
  3. Well i guess Ebay seems ok. just got to see if the seller is reputable.
  4. Hopefully i stay "winning" ok need a case opinion on mother board. pci capture card, Graphics card. HDD . Hmm would a GTX 560 ti be ok? http://www.newegg.com/Product/Product.aspx?Item=N82E16814125401
New Build Monitors Systems
