Power Supply
Last response: in Components
Anonymous
Power supply Expert
Graphics card Master
CPUs Authority
If i had a 500W power supply, and graphics card and CPU in my PC both using 400W.. Would the 700W be able to handle it? (400W + 400W = 800W > 700W) I just want to be entirely sure before building my rig.. Thanks in advance.
More about : power supply
you would need to have a heavy OC to be using 400W on a CPU. id bet its more like 120W at most. as for the video card... even high end cards generally dont use more than 400W unless you buy some dual core monster.
Power supply Master
Graphics card Expert
CPUs Expert
Llama: If you're looking at PSU recommendations from the CPU/GPU mfrs then you're looking at total system power consumption and not power consumption for each part. What are the system components for your build?
Ask the community
