COOLER MASTER Silent Pro Hybrid 850w
Last response: in Components
May 8, 2012 11:23:19 PM
I was curious if someone had the cable lengths for this particular PS. I have been looking for them because I want to know if they can be manageable in my HAF X 942 case with the PS mounted in the bottom of the case. I have been looking around for them and have not found anything on it and would really like to know the specifics before I purchase it.
a c 139 ) Power supply
May 9, 2012 4:26:34 AM
1 x M / B 24 pins (650mm) 25.5"
2x CPU 4 + 4 pins (700mm) 27.5"
6x PCI-e 6+2 pins (600mm)
2x SATA (500mm + 100mm)
5x Peripheral 4 pins (500mm + 100mm)
x1 Floppy 4 pins
x3 Fan cable 3 pins (460mm)
source
m
l
May 9, 2012 6:34:18 AM
Thank you for the reply. I was mostly concerned about the 24 pin connector and the 8 pin connector and that is what I was hoping for.
m
l
a c 111 ) Power supply
May 9, 2012 6:38:26 AM
Those will always be able to fit through the cable management holes.
m
l
