First HTPC build please check parts
- New Build
Systems
- Product
Last response: in Systems
zer0net
January 26, 2012 2:00:01 AM
Hello Everyone,
I'm building an HTPC for the little home entertainment system.
It will be connected to the projector, which is 3D capable,
Purchase date: 1 week.
Use: blue ray, HD movies, Youtube HD, other online streams ie netflix, light gaming like WoW, COD,
Budget: $600 +/- $100
CPU: Intel Core i5-2400 Sandy Bridge 3.1GHz (3.4GHz Turbo Boost) LGA 1155 95W Quad-Core Desktop Processor Intel HD Graphics 2000 BX80623I52400
http://www.newegg.ca/Product/Product.aspx?Item=N82E1681...
MOBO: I dont know which one, please help
Case: LIAN LI PC-V351B Black Aluminum MicroATX Desktop Computer Case
HDD: Seagate Barracuda 7200.12 ST3500413AS 500GB 7200 RPM 16MB Cache SATA 6.0Gb/s 3.5" Internal Hard Drive -Bare Drive (damn they are expensive now)
http://www.newegg.ca/Product/Product.aspx?Item=N82E1682...
GPU: MSI N550GTX-Ti Cyclone OC GeForce GTX 550 Ti (Fermi) 1GB 192-bit GDDR5 PCI Express 2.0 x16 HDCP Ready SLI Support Video Card
PSU: XFX Core Edition PRO550W (P1-550S-XXB9) 550W ATX12V 2.2 & ESP12V 2.91 SLI Ready CrossFire Ready 80 PLUS BRONZE Certified Active PFC Power Supply
RAM: G.SKILL Ripjaws X Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model F3-12800CL9D-8GBXL
CD/DVD: ASUS 24X DVD Burner - Bulk 24X DVD+R 8X DVD+RW 12X DVD+R DL 24X DVD-R 6X DVD-RW 16X DVD-ROM 48X CD-R 32X CD-RW 48X CD-ROM Black SATA Model DRW-24B1ST/BLK/B/AS - OEM
So far without mobo its $763 shipped.
So any suggestions?
So any suggestions?
More about : htpc build check parts
Well, you're already over budget, and you don't have a motherboard or blu-ray drive. Also, given the size of the cooler on the graphics card, I'm not sure if you have the necessary clearance in your case. I'd probably recommend going with an AMD Llano build.
Here's what I've come up with:
Case: LIAN LI PC-V351B - $100
Power Supply: PC Power and Cooling Silencer MK III PPCMK3S500 500W - $85
Motherboard: GIGABYTE GA-A75M-D2H FM1 AMD A75 - $90
CPU: AMD A6-3500 Llano 2.1GHz - $90
RAM: G.SKILL NS 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1333 - $22
Hard Drive: Seagate Barracuda 7200.12 ST3500413AS 500GB 7200 - $100
Optical Drive: LG Black 12X BD-ROM 16X - $65
Operating System: Windows 7 Home Premium SP1 64-bit - $110
Total Cost: $662 + Shipping
Mail in Rebates: $30
Final Cost: $632 + Shipping
The Llano processor has an embedded HD6530 graphics unit. That may be enough for your games, but I don't know about HD3D playback. This EVGA Geforce 550TI is comparable to the card you originally listed (no clearance issues), but at $140, it kills your budget.
-Wolf sends
-Wolf sends
m
l
sadams04
January 26, 2012 12:21:00 PM
MB - ASUS P8H67-M LE - $100
CPU - i5-2400S 65w - $201
GPU - Sapphire HD 6670 Low Profile - $100
MEM - Crucial 8GB DDR3-1333 CL9 1.35v - $40
HD - Seagate 500GB - $100
OPTICAL - ASUS Black 12X BD-RW - $60 after MIR
PSU - XFX PRO550W - $55 after MIR
CASE - Silverstone HTPC - $59
$715
The case accepts four 80mm fans on the right side. All four set up as exhaust will keep overclocked Intel and AMD systems in check. Doubt you will need any at stock speeds (and low voltage for that matter).
$715
m
l
- Building my first desktop. please check parts compatibility, and any advise would be appreciated - Tech Support
- First build, please help checking Parts - Tech Support
- (First Build) Please check if all my parts are compatible! - Forum
- Hi I'm looking to put together my first computer please check compatibility of parts - Tech Support
- First Time Build! Need Parts Checked and Tips Appreciated! Please Help - Forum
geekapproved
January 26, 2012 12:28:22 PM
deadjon
January 26, 2012 12:54:35 PM
m
l
@ Everyone - Please remember the OP is in Canada (inferred by the use of Newegg.ca)
@ GeekApproved - I wanted to go modular, but if that's not an issue for the OP, then the Corsair CX430 - $50 would also be a good choice.
-Wolf sends
Edit: Also, @GeekApproved - With the case the OP selected (I assume that's the preferred choice), the power supply is top mounted over the motherboard. I'd rather not have spare cables dangling above the CPU. Yes, some zip ties and good cable management could resolve that. So could another case.
-Wolf sends
m
l
zer0net
January 26, 2012 1:45:11 PM
Thanx everyone for their replies.
The reason I selected the i5 was because its powerful and i could do some gaming on it occasionally.
If I go with A8-3870K + either 6770 or 550ti GPU would that be a decent combo for gaming?
I dont have to buy the GPU now, I can always add that in later if I feel the need.
would A8-3870K (as suggested by ScrewySqrl) or A6-33500(by wolfshadw) be able to handle Blue-ray/3D without additional GPU?
@Wolfshadw-- as for the blue-ray drive, I have a 5.1 home theater system, the receiver has a blue-ray drive, So i'm thinking i wont need the blue-ray drive in this build.
m
l
deadjon
January 26, 2012 1:59:54 PM
The A8-3870K will handle Blu-Ray/3D playback fine as far as I know.
One of the main features of the Chip is "Blu-Ray 3D"
Avoid the 3870K if your going for a Discrete GPU Higher than a 6670 though.
If you have a 6670 + the 3870k you get HybridXfire - Bringing you 6770 Performance for a lower price.
However, the benefit of the integrated GPU dissapears entirely once you bring anything higher than a 6670 in - it gets disabled by default and you end up with a CPU that costs the same as an i3 with much lower performance and no forseeable benefit over its competition.
m
l
zer0net
January 26, 2012 2:04:57 PM
deadjon said:
The A8-3870K will handle Blu-Ray/3D playback fine as far as I know.One of the main features of the Chip is "Blu-Ray 3D"
So i3 dual-core out performs A8-3870K quad?
Which way would be best, i3+6770 (or 550ti) or A8-3870K + 6670?
m
l
zer0net
January 26, 2012 3:00:20 PM
Wolfshadw said:
If the Home Theater in a Box solution you have includes the Blu-Ray component, there is no need to be concerned about whether the CPU+GPU or APU can handle it (unless I'm missing something).-Wolf sends
Well I was thinking of ripping my Blue-ray to computer..........
... I need a blue ray drive.... Touche Wolfshadw.....touche.....EDIT: @Wolfshadw -- The FM1 mobo you suggested earlier, it seems to have horrible reviews on newegg, people seems to be having video issues with it. Is there any reason you chose that board over another? thanx..
m
l
geekapproved
January 26, 2012 4:47:20 PM
i3/6770 would be better by a mile and a half.
The i3 would destroy the quad. It destroys the X4 965 in gaming, which is much faster than the 3870K.
The only thing about the Llano chips is they have better on-chip grahpics than the i3, but your not going to use that anyways.
The i3 also is only 65w, and without graphics will likely use around 30w.
i3-2120/H61/8GB ram for under $200. Corsair 430w for $16.99. That's a cheap, fast and green setup. The H61 is also upgradable to Ivy Bridge.
m
l
the chief advantage of teh 3870 is that it's all-in-one CPU/GPU. its slower than the i3, but better at multitasking, and has much, much stronger graphics compared to the i3's HD2000/3000.
once you start getting discrete cards over a 6670, the LLano's advantage in grapics disappears.
WITH NO GRAPHICS CARD, the llano is vastly superior on-board graphics (able to do decent 720p gaming at medium settings as is) and advertises being able to decode 3D Blu Ray just fine (something the i3 will need a discrete GPU for)
m
l
rwpritchett
January 26, 2012 7:00:15 PM
geekapproved
January 26, 2012 8:31:35 PM
zer0net
January 26, 2012 9:57:19 PM
Alrighty, i think i'm gonna go with i3 2120 + 550 ti GPU
cpu: Intel Core i3-2120 Sandy Bridge 3.3GHz LGA 1155 65W Dual-Core Desktop Processor Intel HD Graphics 2000 BX80623I32120
mobo: ASRock H61ICAFE LGA 1155 Intel H61 HDMI SATA 6Gb/s USB 3.0 ATX Intel Motherboard
HDD: Seagate Barracuda ST500DM002 500GB 7200 RPM 16MB Cache SATA 6.0Gb/s 3.5" Internal Hard Drive -Bare Drive
RAM: G.SKILL Value Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1333 (PC3 10600) Desktop Memory Model F3-10600CL9D-8GBNT
PSU: COOLER MASTER eXtreme Power Plus RS500-PCARD3-US 500W ATX12V v2.3 Power Supply
Case: SILVERSTONE Black Aluminum / Steel Lascala Series LC13B-E ATX Media Center / HTPC Case
Blue-Ray: SAMSUNG Black 12X BD-ROM 16X DVD-ROM 48X CD-ROM SATA Internal Blu-ray Combo Model SH-B123L LightScribe Support - OEM
$772 shipped...
What do you guys think?
$772 shipped...
m
l
zer0net
January 26, 2012 9:58:06 PM
azeem40
January 26, 2012 10:12:19 PM
geekapproved
January 26, 2012 10:46:13 PM
zer0net said:
Where do you see this combo?I didn't even look at combo's.
http://www.newegg.com/Product/Product.aspx?Item=N82E168... $55
http://www.newegg.com/Product/Product.aspx?Item=N82E168... (Price went up, was $119 a few day's ago) $130
http://www.newegg.com/Product/Product.aspx?Item=N82E168... $25 ar
$210 (2120 price went up)
Why would you choose a CM power supply for $50 +$8 shipping when I suggested one to you that's way better for $17 after rebate and promo code with FREE shipping???
m
l
I don't think GeekApproved has realized you're in Canada yet...
ASRock H61M-VS - $65
Core I3 - 2120 - $130
Patriot Gamer 2 - 8GB RAM (2x4GB) - $35
Corsair CX430 - $50
Total Cost here: $280
-Wolf sends
Corsair CX430 - $50
-Wolf sends
m
l
geekapproved
January 27, 2012 9:48:19 AM
Wolfshadw said:
I don't think GeekApproved has realized you're in Canada yet... ASRock H61M-VS - $65
Corsair CX430 - $50
-Wolf sends
The poster never mentioned Canadian dollars and no I didn't bother looking at the .ca links. I'm not a mindreader.
http://www.newegg.ca/Product/Product.aspx?Item=N82E1681... $30AR
http://www.newegg.ca/Product/Product.aspx?Item=N82E1682... $25AR
http://www.newegg.ca/Product/Product.aspx?Item=N82E1681... $55
http://www.newegg.ca/Product/Product.aspx?Item=N82E1681... $130
$240 CD
m
l
deadjon
January 27, 2012 11:01:12 AM
zer0net
January 27, 2012 12:54:31 PM
geekapproved said:
The poster never mentioned Canadian dollars and no I didn't bother looking at the .ca links. I'm not a mindreader.http://www.newegg.ca/Product/Product.aspx?Item=N82E1681... $30AR
$240 CD
My fault for not mentioning, i'm sorry.
$240 is pretty good for those parts, thanx
m
l
deadjon said:
The 550ti is terrible.Everyone on Tomshardware should be telling you to avoid this card like the plague
the 6790 is a much more powerful card for the same price.
for $10 more than the cheapest 550ti, you can get an HIS HD6850, at least on te US Newegg site. Canada should have something similar.
m
l
zer0net
February 1, 2012 6:27:02 PM
Ok so after thinking alot more about it, i've decided I will not do any gaming on it, simply use it for HTPC purposes (XBMC, youtube, streaming HD content, play blu-ray..etc)
As for the case it will be sitting inside a ventilated cabinet so i'm going to select a cheap case
here are revised parts list, please check,
CPU: A8-3870K
Mobo: BIOSTAR A75MH FM1 AMD A75 (Hudson D3) HDMI SATA 6Gb/s USB 3.0 Micro ATX AMD Motherboard
RAM: G.SKILL 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Dual Channel Kit Desktop Memory Model F3-12800CL9D-4GBNQ
Blu-ray: SAMSUNG Black 12X BD-ROM 16X DVD-/+R 48X CD-ROM SATA Internal Blu-ray Combo Model SH-B123L/RSBP LightScribe Support
Case: HEC 6K28BS Black / Silver 0.8mm SECC Steel MicroATX Mini Tower Computer Case
PSU: CORSAIR Builder Series CX430 V2 (CMPSU-430CXV2) 430W ATX12V v2.3 80 PLUS Certified Active PFC Power Supply
Total: CAD$ 555 delivered.
Thanx
CPU: A8-3870K
Thanx
m
l
just on brand reputation, I'd consider the AMD A75 board for $10 more
http://www.newegg.ca/Product/Product.aspx?Item=N82E1681....
also consider this case:
120mm fans = better cooling
m
l
zer0net
February 1, 2012 7:02:19 PM
ScrewySqrl said:
just on brand reputation, I'd consider the AMD A75 board for $10 morehttp://www.newegg.ca/Product/Product.aspx?Item=N82E1681....
How about this one?
GIGABYTE GA-A75M-S2V FM1 AMD A75 (Hudson D3) SATA 6Gb/s USB 3.0 Micro ATX AMD Motherboard
m
l
zer0net
February 1, 2012 8:39:55 PM
are you talking about this board?
it seems to have awful reviews.
m
l
- SolvedCheck this powerful PC build's parts and give feedback, please solution
- SolvedFirst build - Computer parts check solution
- SolvedFirst build: $700 or less multimedia editing pc (check parts?) solution
- Solvedcheck it out please first build need expertise solution
- SolvedFirst build htpc - help on parts list Forum
- First build parts check on $900 gaming PC Forum
- SolvedFirst Build, Parts Check, Any Good? solution
- SolvedBuilding new gaming desktop - please check over my parts list? :D solution
- SolvedNeed to check if these parts work together (First build) Forum
- Please discuss & help me with my first HTPC (parts list) Forum
- SolvedPlease help,general question about system stability and performance(First manual build check) solution
- SolvedFirst time building - parts check solution
- First Time gaming/media/htpc build, picked out parts, but could use some confirmation and guidance Forum
- SolvedAdvice for my First Build, Please check solution
- SolvedFirst desktop build. Don't know if parts are compatible. Please help!!! solution
- More resources
- You wont even be able to find the thing it'll be that tiny.
