Which case is best for my parts?
6 answers Last reply
More about which case parts
  1. Phantom provides better cooling!
  2. They are both great cases i own both of them but the Thermaltake Chaser MK-I is better imo
  3. And yes the Thermaltake Chaser MK-I will work with that setup
  4. The reason i pick Thermaltake Chaser MK-I is it's bigger and provides better options and future upgrading It would probably also be a good idea to get some cheap but nice case fans later down the road too. A couple of these would probably do the trick (They also come with red or blue LEDs):
    http://www.newegg.com/Product/Product.aspx?Item=N82E16835103090#top
  5. Front (Intake) :
    200 x 200 x 30 mm Colorshift fan x 1 (600~800rpm,13~15dBA) or 120 x 120 x 25 mm x 2 (optional) Rear (Exhaust) :
    140 x 140 x 25 mm TurboFan, 1000rpm, 16dBA or 120 x 120 x 25 mm x 1 (optional)
    Top (Exhaust) :
    200 x 200 x 30 mm Colorshift fan x 1 (600~800rpm, 13~15dBA); 200 x 200 x 30 mm x 1 (optional) or 140 x 140 x 25 mm x 2 (optional) or 120 x 120 x 25 mm x 2 (optional)
    Bottom (Intake) :
    Side (Intake) :
    FRONT, 1 X 140mm
    REAR, 1 X 120mm (included)
    SIDE, 2 x 120mm, 1 x 200/230 (2 x 120mm included)
    TOP, 2 X 200mm (1 x LED 200mm included)
    Looks like the Phantom is better for watercooling :wahoo:
  6. There both great cases i would know since i own both the Thermaltake Chaser MK-I or NZXT Phantom will work fine pick the one you like better
Power Supplies Thermaltake Cases Motherboards Hard Drives Components Product
