Will my cpu work with this motherboard?
Hello i want to ask if AMD Athlon II X4 651 Black Edition will work on n68c s ucc motherboard and how much better is it than AMD athlon ii x3 440 thx
8 answers Last reply
More about will work motherboard
  1. No, the 651 is fm1 socket and the motherboard you have is am3.
  2. and will AMD Phenom II X4 965 Black Edition work with this motherboard?
  3. Yes. It will also perform much better due to the higher clock and l3 cache.
  4. and i am thinking to rebuild my pc specs procesor and ram now and others later so i need help with 1 more thing.
    CPU:AMD FX-6100 or AMD FX-6200 or AMD Phenom II X4 965 Black Edition (please tell me which cpu to choose)
    RAM:Kingston 8GB KIT DDR3 1600MHz CL9 HyperX X2 Grey Series (please say what you think about this ram)
    thank you in advance i want to know what to choose
  5. AMD Phenom II X4 965 Black Edition :D
  6. And btw, welcome to the forums :)
  7. could you tell me why? because the other ones have more cores and more caches
    Biggest reason would be that your motherboard doesn't support the FX series of processors. Other then that depending on what you do the 6100 isn't really faster than the Phenom II 965. And technically the fastest processor supported on your board is the 945, 960T, or 1055T.
    Supported CPU list also lists the minimum required BIOS for each chip -> http://www.asrock.com/mb/cpu.asp?Model=N68C-S%20UCC
    Your motherboard does not support 125W chips which means the Phenom II 965 is not supported.
CPUs AMD Motherboards
