I want the best bang for the buck to build up to date rig.
Approximate Purchase Date: This month or the next one
Budget Range: $500
System Usage from Most to Least Important: Gaming
Parts Not Required: Hard drive
Preferred Website(s) for Parts: Any that is cheap and good
Country: New York, USA
Parts Preferences: Intel I5 2500k or AMD equivalent but is cheaper
Overclocking: Maybe
SLI or Crossfire: No
Monitor Resolution: 1024x768
Additional Comments: I will need a case, power supplier, mobo, ram and either air or water cooling for the cpu.
I was thinking maybe I would wait for the Ivy bridge processor to come out to get the I5 2500k cheaper or getting and AMD alternative cheaper but on par. And buy everything in separate bundles excluding the hard drive and maybe use my old video card for the resolution I am using currently (Ati HD 5750)
Budget Range: $500
Overclocking: Maybe
