550 txi graphics card power supply
the 6pin plug split into two seperate connectors do both of thes need to connected to the power supply ?evga graphics card.I have a AS rock motherboard with onboard graphics and a 500w power supply
1 answer Last reply
More about graphics card power supply
  1. Your power supply should already have a lead with a 6-pin connector.
    You only have to use the adapters that came with your GPU if you don't have an available cord already.
    Connecting the cable is as simple as find a 6+2pin cable and plug it into the GPU.
    You may find your 6-pin has an extra 2 pins hanging off it, that's to connect it to a more powerful GPU that requires 8-pin power.
    I hope this helps you out.
Graphics Cards Power Supplies Graphics
