Solved
My hard drive wont start up, But my fans and everything else will.
Removed 250gb hdd that had a warning of impending disk failure. Installed a 1.5TB HDD, fans turn on, and a blank screen.
4 answers Last reply Best Answer
More about hard drive wont start fans will
  1. did you install a os on the harddrive?
  2. Best answer
    Hello !
    First off, this topic should be moved in the "Storage\Hard Drives" section.
    Secondly, the HDD you removed, was it your Boot drive (was your OS installed on that drive) ? Is the "blank screen" a black screen ?
    If it was, it could be that after POSTing, your computer can't do anything else because no OS is installed on that drive.
    Get back to me on that,
    al360ex
  3. Best answer selected by planedr.
    As it turned out, I found the problem to be a bad memory. What I did was re-install the old hard drive, still had the problem. I remembered I had this same problem years ago. I removed and tested each memory panel and found one bad.
    I do want to thank you because I keep these suggestions in a card file.
Hard Drives Components
