Need help! New system build, major crash, unable to restart!!
torenator
I just recently purchased and built this system:
http://www.newegg.com/Product/ComboBundleDetails.aspx?ItemList=Combo.770956&cm_sp=DIY_PC_Combos-_-770956-_-Combo&nm_mc=AFC-C8Junction&cm_mmc=AFC-C8Junction-_-RSSDailyDeals-_-na-_-na&AID=10521304&PID=4176827&SID=1vueskcit0gjd
I installed Windows 7 Professional 64 bit and everything was going really well until... my computer hard crashed mid-game. It froze for a second, made an unpleasant noise for another second, and everything shut down completely. When I tried to turn it back on I push the power button and the LEDs comes on and the fans spin for about a half second to a second, then shut down. It tries to restart itself after about 2 seconds and the same thing happens. This continues until I shut off the power supply.
What happened? Did something overheat? Is something broken? Please help!!
Thank you!
Unfortunately, that combo included one of the more fecal CM PSUs: http://www.hardwaresecrets.com/article/Cooler-Master-eXtreme-Power-Plus-600-W-Power-Supply-Review/1034/9
No doubt, it could not hold up its end of the log, and croaked. Hopefully it did not take any other parts with it when it died. You will need to replace it.
A quality modern PSU has full range active PFC (no little voltage switch) and some level of 80+ certification for efficiency. Seasonic, Antec, Corsair, XFX, and Enermax/LEPA are among the better brands. A good 500W PSU would be sufficient for that PC (e.g. a 500W Antec Earthwatts).
torenator
Motherboard:
GIGABYTE GA-Z68MA-D2H-B3 LGA 1155 Intel Z68 HDMI SATA 6Gb/s USB 3.0 Micro ATX Intel Motherboard (Model:GA-Z68MA-D2H-B3)
Graphics Card:
GTX 560 Ti
CPU:
Intel Core i5 2500K
RAM:
G.SKILL Ripjaw X series 8GB
HD:
Seagate Barracuda 500GB
You can see the whole list of components on Newegg via the link I posted as well.
torenator
Unfortunately I don't have another PSU lying around, any way to know for sure if this is the problem? And if so, any way to know if it took anything else with it until I get a new PSU?
torenator
Clearing the CMOS did not help :(
Also, I pulled the graphics card and the memory out. This allowed it to whirl up for a bit longer, about 10 seconds, but then it died again and continued to try to restart itself unsuccessfully as before.
torenator
I have replaced the PSU with a Corsair GS600 600W.
It did not improve the situation at all. Same thing happens, it tries to start up for a second, then dies, and continues to repeat until I disconnect power.
So it's not the PSU, and this really bums me out. What am I looking at next, the motherboard? Is there no way for me to tell whether it's the motherboard or the CPU at this point?
*Note: I previously did not have the motherboard speaker installed. Now that I do, when I start it up without the RAM, I get continuous beeping for about 10-15 seconds as it sounds like everything is starting up, then it cuts out. It tries to repeat this process.
My motherboard manual says that continuous short beeping is a power error, and continuous long beeps is a "graphics card not inserted properly. I feel like they are long beeps, but I can't be sure because I haven't heard a short beep. Basically I think it was giving an error that the graphics card wasn't inserted properly because it was missing RAM. But with the RAM installed I get no beeps at all and nothing starts up, but for a fraction of a second.
torenator
Ok I believe I have solved the issue. It turns out that just ONE of my RAM sticks was bad. I know it sounds crazy but when I removed only one of the sticks of RAM, everything worked perfectly. I switched it with the one I had left on the mobo just to be sure it wasn't the RAM slot and it stopped working again.
So something happened while I was gaming that fried that stick of RAM to the point that it was preventing my entire system from even booting into the bios. Very weird.
Thanks for all the suggestions. I would never have figured it out if someone hadn't suggested removing the RAM in the first place, as that led to me thinking that I should just try leaving one in.
torenator
Yea, I'm keeping the Corsair I bought after reading everyone's thoughts on Crapper Master. The one review said it isn't even truly 600W, that it really only pushes 450W...
