Solved
Hdmi cables eliminate what other cables when connecting TV to Comcast receiver?
Best solution
Yes.
HDMI cable is the only cable you need, it contains both digital video and audio. It is also is the method that gives you the highest quality signal possible right now.
benchlegs said:
Does the application of an HDMI cable between an HD TV and the Comcast 'box' eliminate the RGB cable and the other cable for video and sound?
Thanks for your reply. Much appreciated.
Benchlegs
Ask the community
