i'm not sure if this problems goes here, but i didn't know where else to put it.
i bought a pc, like two months ago. I had unexpected restarts under ubuntu 7.04 and windows xpsp2.
I ran stress tests on the machine to make sure everything was ok. memtestx86+ 1.70 didn't give me any problems after running it for about 14 hours.
Then I ran orthos and it gave me the "rounding error expected <0.4 was 0.5" message, or something like that (blend and large tests running together, and each failed at least once)
Super Pi gave me "not convergent in sqrt(5)" and "not exact in rounding" errors.
Now the problems is that i sent it to technical support and they told they didn't had any problems with the same programs i used, yet, when i got it back last wednesday i had the same errors once again.
What can be the problem??? (besides the store trying to sell me bad hardware)
I ran Sandra last night and it gave me no problems, but in "Tools-> Analysis and Advice" it said "Warning 236: Vcore higher than rated maximum. Check Vcore settings!" Now, that tells me something... but, what it's the correct setting if it is wrong? in the BIOS everything is on "auto" except for the memory latencies 4-4-4-12.
this are the main components:
MB: Asus P5N-E SLI (I think the bios version 0202)
CPU: Intel Core 2 Duo E6600@2.4Ghz (vcore 1.360v according to cpu-z 1.40)
RAM: Corsair TWIN-X 1GB (2X512) 6400C4 800MHZ PC2-6400
Video: MSI V032-130 RADEON X1050-TD128E PCIE 16X 128MB
PS: Coolermaster eXtreme Power 600W
Any ideas on how to make this problems go away? Or maybe the hardware is deffective and needs replacement?
Thanks for your help.
