I am getting the GTX 560ti card. It is my first time ever getting a graphics card, so im confused. It comes with two-6 pin power connectors, seen in these images. http://www.newegg.com/Product/Product.aspx?Item=N82E16814130683 My question is the card has two slots on the back to fit these two 6pin power connectors, but do you plug both in? and where does the other ends plug into the power supply? Im terribly confused and can't seem to find instructions for these wires. They say the card can't run without them Please help me out guys. Thanks.
