imconfsdru
19
Okay this is the build I am considering putting together and its right at where my budget allows currently please any thoughts critiques etc...???
P.S. I know its an old discontinued MB and It's only a single graphics card but again budget but please what do you all think??? Im not overclocking so didn't get the Black Edition I know I should have...
Operating System
MS Windows 7 64-bit
CPU
AMD Phenom II X6 1055T Thuban 45nm Technology
RAM
G.SKILL Ripjaws Series 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800)
Motherboard
ASUSTeK Computer INC. M4A785TD-V EVO (AM3)
Graphics
VS248 (1920x1080@60Hz) 24' Led HD monitor
1024MB GeForce GTX 560 Ti (ASUStek Computer Inc)
Hard Drive
Seagate Barracuda 7200.12 ST31000528AS 1TB 7200 RPM SATA 3.0Gb/s 3.5" Internal Hard Drive -Bare Drive
Power Supply
OCZ ModXStream Pro 700W Modular High Performance Power Supply
Case
Antec Lanboy air Yellow Black / Yellow Steel / Plastic ATX Mid Tower Computer Modular Case
g-unit1111
I'd actually drop the case and invest the difference in getting an i5-2500K setup.
Try this:
Case: http://www.newegg.com/Product/Product.aspx?Item=N82E16811119233
Motherboard: http://www.newegg.com/Product/Product.aspx?Item=N82E16813157271
CPU: http://www.newegg.com/Product/Product.aspx?Item=N82E16819115072
RAM: http://www.newegg.com/Product/Product.aspx?Item=N82E16820231314
Cooler: http://www.newegg.com/Product/Product.aspx?Item=N82E16835103099
And then for the video card and PSU these would be better choices:
Video card: http://www.newegg.com/Product/Product.aspx?Item=N82E16814130604
PSU: http://www.newegg.com/Product/Product.aspx?Item=N82E16817139020
That will be a far better setup than the X6 - I use it and I actually prefer my Z68 setup over it (uses i3-2120).
