Possible power surge? please help fast
  • Power Supplies
  • Components
  • Product
Last response: in Components
May 11, 2012 12:49:52 AM
hi. today i was doing online school and suddenlely my computer turned off. ok. i thought it was a power supply problem. i flicked the switch at the back of the power supply and it turned on. i turned the pc off and put the switch back to its orignal state. still turns on. when i try to boot it says: no boot devide selected please insert proper boot device. WTF? now im really scared. it also beeps 3 times then pauses then beeps 3 times again. it doesnt stop beeping. now im worried my hard drive and mobo are destroyed. i have a surge protector so i dont know what happened. i reset to default bios settings but still no luck whats wrong with my computer?
asus p5g41t m lx plus
xfx 5450
intel core 2 qaud 2.66 ghz
2 gig RAM
diamond sound card.
random laptop hard drive
More about : power surge fast
May 11, 2012 12:58:27 AM
Here are the beep codes for your motherboard http://support.asus.com/Troubleshooting/detail.aspx?SLa...
note there is no 3 beeps-pause-3 beeps. there is a 1 long and 2 short beep which would signify a memory error. if that is the case, try each stick of memory in the first dimm slot 1 at a time and try to post. There is also 1 long and 3 short beeps, which would be a graphics error. try running off another graphics card to see if it posts if this is the case.
m
l
May 11, 2012 1:01:55 AM
Exactly what little switch on the power supply did you flick? You seem to have automatically decided it was a power supply problem when your pc shut down..why, has it happened before and flicking this switch helped? What power supply do you have?
m
l
May 11, 2012 1:06:50 AM
ok now its turning on but ocasionally turns off and on on its own. and it does not detect the HDD i tried one that was not connected when it shut down originally but no go. now im confused. UPDATE:o k now its not turning on again. earlier when it did turn on it only sounded the 1 short POST beep so there seems to be nothing wrong but yeah it stoppped turning on again.
m
l
May 11, 2012 1:08:21 AM
the red one that changes tfrom 115 to 220 or sumething
m
l
May 11, 2012 1:11:53 AM
This switch switches from US electricity to European electricity and you should not mess with it. Turning it on with the 220 setting can damage the parts in your computer.
m
l
May 11, 2012 1:13:06 AM
so wut can i do to get my computer working
m
l
May 11, 2012 1:18:55 AM
you should test the system with a known good psu and cross your fingers.
m
l
May 11, 2012 1:25:42 AM
um i think i may have murdered my power supply. i tried booting with an old 300 watt and the mobo led is on! i do not dare plug in a video car cuz everything is really dim. and a little qiuet. so how can i tell if its my mobo or my psu without plugging in a gpu
m
l
May 11, 2012 1:28:04 AM
You will need to know if the system will boot. either you will have to end up purchasing a new psu or you will have to attempt to test the full boot with another psu (such as the 300w you used). does your motherboard have on board video? If so, use that to test the boot.
m
l
May 11, 2012 1:30:13 AM
If your CPU has integrated graphics, remove the GPU and plug your monitor into the MB to check (fingers crossed)
m
l
May 11, 2012 1:47:05 AM
yes the mobo has integrated but it never worked. the mobo turns on but no video even with gpu. i will try using psu in diffrent comp0uter. otherwise is it safe to assume its the motherboard that is damaged? btw its like 40 bucks for psu and mobo lol
m
l
May 11, 2012 1:48:59 AM
if you cannot get your spare psu to work i would try to have the parts tested by swapping them out in another machine. could be the motherbaord. could be cpu. could be both.
m
l
May 11, 2012 1:55:08 AM
the psu is fried. the mobo turns on although doesnt show up with monitor with the 300 watt psu. i hope the motherboard isnt dead. win7 is OEM
m
l
May 11, 2012 1:57:58 AM
whats a good psu at least 550 watt under 50 bucks? im gonna buy a new psu and if i need to a new mobo. and windows 7, can i just return it and order a new one? lol i havent removed the sticker yet.
m
l
May 11, 2012 6:37:54 PM
thank you that is a good price and a good brand. the psu i got was really bad it was a blue star.
m
l
May 11, 2012 6:50:30 PM
thank you guys for all the help. i opened my PSU and discovered a blown fuse. well even that didnt protect my mobo. so now i have to replace my mobo and psu ( with a better one) and possibly my RAM and cpu. i hope my cpu isnt busted. im taking it to a computer fixer in town to test the RAM and cpu.
m
l
May 12, 2012 5:09:04 AM
sorry about your luck and wish you better in the future!
m
l
May 12, 2012 5:44:37 AM
When you are dumb enough to switch the voltage switch on your psu because your pc shut down, you kinda deserve a few blown parts
m
l
a c 158 ) Power supply
May 12, 2012 10:36:39 AM
I guess you came out of the womb all-knowing with immaculate experience. It's a hard lesson to learn, but no one deserves blown parts.
m
l
