Closed Solved
Need advice on first pc build $500
Approximate Purchase Date: Within a week.
Budget Range: Around $500
System Usage from Most to Least Important: Gaming (skyrim, bf3, metro 2033, SWTOR, etc.)
Parts Not Required: OS, Keyboard , Mouse, graphics card (Galaxy GTX 480)
Preferred Website(s) for Parts: amazon.com, (Microcenter for cpu)
Country: Michigan, USA
Overclocking: Maybe
SLI or Crossfire: No
Monitor Resolution: 1920x1080.
cpu i3-2100 $99.99 http://www.microcenter.com/single_product_results.phtml?product_id=0359809
mobo GIGABYTE GA-H61M-DS2 $52.99 http://www.amazon.com/GIGABYTE-GA-H61M-DS2-Intel-Micro-Motherboard/dp/B005PX3UYA/ref=sr_1_4?ie=UTF8&qid=1327707764&sr=8-4
Psu Corsair Builder Series CX600 $69.99 http://www.amazon.com/Corsair-Certified-Compatible-Platforms-CMPSU-600CXV2/dp/tech-data/B004W2T2UQ/ref=de_a_smtd
Ram- need suggestions. has to be 1.5v correct?
hard drive need suggestions
case need suggestions
dvd drive need suggestions
anything else i am forgetting about? Also just want to make sure the i3-2100 wont bottleneck the gtx 480??? may need to upgrade towards a i5-2400 or 2500k possibly. Also will the psu be powerful enough, as well as have the neccesary connectors for gpu?
Thanks
8 answers Last reply Best Answer
More about need advice build
  1. Intel Core i5 2400 LGA 1155 Boxed Processor - $149.99
    http://www.microcenter.com/single_product_results.phtml?product_id=0354589
    Gigabyte GA-Z68MA-D2H-B3 LGA 1155 Z68 mATX Intel Motherboard - $104.99 after rebate savings
    http://www.microcenter.com/single_product_results.phtml?product_id=0364087
    Western Digital Caviar Blue 320GB 7,200 RPM SATA 6.0Gb/s 3.5" Internal Hard Drive - $89.99
    http://www.microcenter.com/single_product_results.phtml?product_id=0352162
    CORSAIR Vengeance 8GB (2 x 4GB) 240-Pin DDR3 1600 - $49.99
    http://www.newegg.com/Product/Product.aspx?Item=N82E16820145345
    Lite-ON 24X SATA DVD Burner - $17.99
    http://www.microcenter.com/single_product_results.phtml?product_id=0322335
    NZXT Classic Series Source 210 Mid Tower ATX Computer Case - $27.99 after rebate savings
    http://www.microcenter.com/single_product_results.phtml?product_id=0378074
    Corsair Builder Series CX600 - $69.99
    Total : $440.94 + $69.99 = $510.93
  2. Okay so I have put together a new build let me know what ya'll think. Also i have $200 Amazon credit... If you buy the 2500k with mobo from microcenter you get $50 off mobo.. So this is actually cheaper than going with an i5 2400 because of the savings on the mobo...
    Intel Core i5 2500K LGA 1155 Boxed Processor $179.99
    Gigabyte GA-Z68AP-D3 LGA 1155 Z68 ATX Intel Motherboard $49.99 after rebate savings
    http://www.microcenter.com/single_product_results.phtml?product_id=0375352
    Hitachi 7K1000.C 500GB HDS721050CLA362 7200 RPM 16MB Cache SATA 3.0Gb/s 3.5" Internal Hard Drive $89.99
    http://www.microcenter.com/single_product_results.phtml?product_id=0349595
    Lite-ON 24X SATA DVD Burner - OEM $17.99
    Total for microcenter store pick up with tax= $368.84
    Zalman Z9 Plus Atx Mid Tower $73.99
    http://www.amazon.com/gp/product/B004I44G5E/ref=ox_sc_act_title_3?ie=UTF8&m=ATVPDKIKX0DER
    Corsair Vengeance 8 GB ( 2 x 4 GB ) DDR3 1600 MHz (PC3 12800) 240-Pin DDR3 Memory Kit $49.99
    http://www.amazon.com/gp/product/B004CRSM4I/ref=ox_sc_act_title_2?ie=UTF8&m=ATVPDKIKX0DER
    OCZ ModXStream Pro 700W Modular High Performance Power Supply $79.99
    http://www.amazon.com/OCZ-ModXStream-Modular-Performance-compatible/dp/B001IZ7MHU/ref=sr_1_1?s=electronics&ie=UTF8&qid=1327786179&sr=1-1
    Total for Amazon = $203.97
    Galaxy 80XLH5HS8GUX GeForce GTX 480 1536MB 384-bit DDR5 PCI Express Video Card (Brand New) $Already own
    http://www.newegg.com/Product/Product.aspx?Item=N82E16814162050
    Grand total- $572.81
    Any feedback is greatly appreciated! thank you.
  3. Think I might go with this mobi instead of the gigabyte..
    ASUS P8Z68-V LX LGA 1155 Z68 ATX Intel Motherboard $69.99
    http://www.microcenter.com/single_product_results.phtml?product_id=0371775
    What do you think?
    Also added a cooler master hyper 212 evo to my cart on microcenter for $36.
  4. Best answer
    Go with the ASUS mothyerboard. The boards have minor differences, but the ASUS motherboard has Manufacturer Warranty of 3 years while GIGABYTE has 1 year.
  5. Thanks for the help ujaansona.
  6. You are welcome. :)
  7. Best answer selected by atc250es.
  8. This topic has been closed by Mousemonkey
New Build Systems Product
