so my first initial build was an i5-2500k and radeon 6870 combo for my multimedia course in college...I would be using photoshop,AutoCAD, and other multimedia stuff but just now i considered taking computer science and that said I wont be using CPU intensive programs and I've changed my build to 2500k/6870 combo to a 2400/560Ti or 6950 combo(i skimped down on the CPU because im on a budget and the saved money will go to the GPU )
So now my build is only just for gaming,web surfing,paper work,Movie watching, and very little photoshop...so is the 2400/560Ti or 6950 combo better for gaming? and skimping down on the CPU will have a great affect on gaming??Should I also settle for a P67 mobo instead of a z68 mobo?
here's the rest of my build:
Case:Corsair Carbide 400r
Mobo:Gigagbye Z68x UD3H B3 Rev 1.3
PSU:CoolerMaster Silent Pro M700w
HDD:WD Caviar blue 500gb
RAM:Corsair Vengeance 8gb
CPU Cooler:CM Hyper 212 Evo
Win7 OEM
and ohhh if I pick the 2400 should i just stick with the stock cooler??
TNX IN ADVANCE!!
Win7 OEM
TNX IN ADVANCE!!
