Double check on $500 gaming pc (are these parts good + compatiable)
the_monomer
9
Approximate Purchase Date: this week( probably going to wait for some parts to have specials)
Budget Range: <500 after rebates
System Usage from Most to Least Important: gaming (just needs to be able to run starcraft 2 basically)
Parts Not Required: keyboard, mouse, speakers, OS
Preferred Website(s) for Parts: newegg.com, microcenter, frys(i have a 100$ giftcard there)
Country: US
Overclocking: No
SLI or Crossfire: No
Monitor Resolution: I would be getting a new one.
Additional Comments: I just wanted to double check to make sure these parts were compatiable. Also, if you see a part that could be easily upgraded or one that isn't very good, feel free to let me know (I am relatively new to building my own pcs). Thanks
Mobo:
ECS H61H2-M2(1.0) LGA 1155 Intel H61 Micro ATX Intel Motherboard
http://www.newegg.com/Product/Product.aspx?SID=u0t0f0fp67262dd0c0s701&AID=10440897&PID=1225267&nm_mc=AFC-C8Junction&cm_mmc=AFC-C8Junction-_-cables-_-na-_-na&Item=N82E16813135288
$24 after MIR and promocode
GPU:
Radeon HD 6870 1GB 256-bit GDDR5 PCI Express 2.1 x16
http://www.newegg.com/Product/Product.aspx?Item=N82E16814150521
$150 after MIR
CPU
Core i3 2100 LGA 1155 3.1GHz Boxed Processor
www.microcenter.com/single_product_results.phtml?product_id=0359809
$99
psu:
CORSAIR CX500
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139027
$50 after MIR
HD:
HITACHI HDS721050CLA362 (0F10381) 500GB 7200 RPM 16MB Cache SATA 3.0Gb/s 3.5" Internal Hard Drive -Bare Drive
http://www.newegg.com/Product/Product.aspx?Item=N82E16822145299
$80
Memory:
G.SKILL NS 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1333 (PC3 10600)
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231394
$21 (no "heat spread". will that make much of a difference? should i shell out the extra 9 bucks to get "heat spread"?)
Case:
Rosewill R102-P-BK 120mm Fan MicroATX Mid Tower Computer Case
http://www.newegg.com/Product/Product.aspx?Item=N82E16811147111
$30
total: 474 (without monitor and cdrom drive)
For Starcraft 2, a 6850 card would work just as well and save a few $. The 6850 would also not get as hot in that small case.
I would add a front fan to the case blowing in(intake). The rear that comes with it will be blowing out of course. This one has a 3 speed switch which you should be able to set on low. They are nearly silent at all speeds. http://www.newegg.com/Product/Product.aspx?Item=N82E16835209005
I would use the savings on the vid card to upgrade the motherboard. ECS is usually not very good, and with the low cost of that one, it is likely a problematic "get rid of 'em cheap" deal. This would serve you very well. http://www.newegg.com/Product/Product.aspx?Item=N82E16813128527
edit: In your case, the heat spreader on...
tlmck
edit: In your case, the heat spreader on the ram would be just unseen decoration.
