Hi Guys, this is gonna be my first attempt to build a PC myself. Please give me some advice and see if my build works. This rig is mainly for playing Starcraft 2 and some daily tasks such as surfing internet and using MS Office for work. I do open a lot of windows when I work with Excel due to my profession. I found that Excel can be very slow sometimes with the dell computer I have in my office. First of all, I need some advice on the MOBO. Should I get a Asus Z68 gen3 or gen3 is useless? I have no idea if I should overclock my cpu and gpu. Is a single 570 at clock is enough for SC2? I do plan on put another 570 in my rig later on when it gets cheap. Is 922 a big enough case or I should go for 932? I was also wondering if I should get i2600K because I run many apps(again MS Office, browsers and maybe itune) at same time. I already have a brand new seasonic X750. Do you guys think it will be enough for future 570 SLI? Any input will be appreciated. Thank you.
Approximate Purchase Date: the closer the better
Budget Range: $1500
System Usage from Most to Least Important: gaming, MS Office w/ 10+ window, surfing the internet
Parts Not Required: keyboard, mouse, monitor, speakers
Preferred Website(s) for Parts: newegg.com
Country: USA
Parts Preferences: Intel and Nvidia
Overclocking: Maybe
SLI or Crossfire: Maybe
Monitor Resolution: 1920x1080
Additional Comments: I would like a quiet PC
Include a list of any parts you have already selected with descriptively labeled links for parts.
The easiest method is to paste the label on one line and then paste the link below it.
Intel Core i5-2500K Sandy Bridge 3.3GHz (3.7GHz Turbo Boost) LGA 1155 95W Quad-Core Desktop Processor Intel HD Graphics 3000 BX80623I52500K
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115072 ]
EVGA 012-P3-1570-AR GeForce GTX 570 (Fermi) 1280MB 320-bit GDDR5 PCI Express 2.0 x16 HDCP Ready SLI Support Video Card
http://www.newegg.com/Product/Product.aspx?Item=N82E16814130593 ]
ASUS P8Z68-V PRO/GEN3 LGA 1155 Intel Z68 HDMI SATA 6Gb/s USB 3.0 ATX Intel Motherboard with UEFI BIOS
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131790&nm_mc=OTC-Froogle&cm_mmc=OTC-Froogle-_-Motherboards+-+Intel-_-ASUS-_-13131790 ]
SeaSonic X750 Gold 750W ATX12V V2.3/EPS 12V V2.91 SLI Ready 80 PLUS GOLD Certified Modular Active PFC Power Supply
http://www.newegg.com/Product/Product.aspx?Item=N82E16817151087 ]
G.SKILL Ripjaws Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model F3-12800CL9D-8GBRL
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231314 ]
Crucial M4 CT128M4SSD2 2.5" 128GB SATA III MLC Internal Solid State Drive (SSD)
http://www.newegg.com/Product/Product.aspx?Item=N82E16820148442 ]
COOLER MASTER Hyper 212 Plus RR-B10-212P-G1 "Heatpipe Direct Contact" Long Life Sleeve 120mm CPU Cooler Compatible Intel Core i5 & Intel Core i7
http://www.newegg.com/Product/Product.aspx?Item=N82E16835103065 ]
COOLER MASTER HAF 922 RC-922M-KKN1-GP Black Steel + Plastic and Mesh Bezel ATX Mid Tower Computer Case
http://www.newegg.com/Product/Product.aspx?Item=N82E16811119197 ]
Budget Range: $1500
Country: USA
Overclocking: Maybe
