New build [Around 1200-1500$] Completly new to building systems
Last response: in Systems
Hey, I plan on building a new system. I've always bought pre-built systems in the past such as gateway or hp and I got raped obv.
I'm new so should I just buy the parts suggested in the buying guide for my price range and follow the guide to assemble it ?
Heres what I would need.
Approximate Purchase Date: (e.g.: this week (the closer the better))
ASAP
Budget Range: (e.g.: 600-800) Before / After Rebates
1200-1500
System Usage from Most to Least Important: (e.g.: Folding@Home, gaming, surfing the internet, watching movies)
Playing poker, gaming, watching movies, internet
Parts Not Required: (e.g.: keyboard, mouse, monitor, speakers, OS) **Include Power Supply Make & Model If Re-using**
Monitor,keyboard,mouse,speakers
Preferred Website(s) for Parts: (e.g.: newegg.com, ncix.com -- to show us selection & pricing)
Any that ships to canada with good pricing and shipping rates
Country: (e.g.: India) we need to know where these parts are being assembled
Canada
Parts Preferences: by brand or type (e.g.: I would like to use an AMD CPU & Biostar mobo with a 24" LCD and full tower case)
Intel cpu
Overclocking: Yes / No / Maybe
I'm new to this but i could try
SLI or Crossfire: Yes / No / Maybe
I dont care
Monitor Resolution: (e.g.: 1024x768, 1280x1024, 1440x900, 1600x1200, 1680x1050, 1920x1080, 1920x1200)
1920x1080
Additional Comments: (e.g.: Need to have a window and lots of bling, I would like a quiet PC)
I need a SSD, I also need a video card that support dual monitors. quiet pc would be nice . Need to buy windows.
Based off your requirements I'd recommend a build similar to what I use for my workstation. If internet is your main priority you don't really need to OC or purchase an unlocked CPU.
Try this:
Case: Fractal Design Arc MIDI - $99.99
PSU: Corsair Enthusiast Series TX650 - $89.99
Motherboard: Gigabyte GA-Z68XP-UD3H - $159.99
CPU: Intel Core i5-2400 - $189.99
Cooler: Cooler Master Hyper 212 Evo - $34.99
RAM: PNY XLR8 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 - $44.99
SSD: Samsung 830 64GB - $119.99
HD: 500GB Western Digital Caviar Blue - $84.99
Video Card: Sapphire Radeon HD 6950 - $259.99
OS: Windows 7 Home Premium - $99.99
Total: $1,214.99
What do you guys think about this build :
Core i5 2500k @ $220 (pricematch with http://www.bestdirect.ca/products/232639/Intel/BX80623I... )
http://www.ncix.com/products/?sku=57962
HIS Radeon HD6870 @ $160 ($150 after mail in rebate)
http://ncix.com/products/?sku=66643&promoid=1141
Mushkin 2x4GB 1333MHz @ $40 ($35 after mail in rebate) (pricematch with http://www.directcanada.com/products/?sku=16950BD3503 )
http://ncix.com/products/?sku=55544
XFX Core Edition 550 @ $62 ($47 after mail in rebate) (pricematch with http://www.directcanada.com/products/?sku=15180AC2961 )
http://www.ncix.com/products/?sku=59615
ASUS P8Z68-M Pro @ $122 (pricematch with http://www.hookbag.ca/product/H3C06MO4O/ )
http://ncix.com/products/?sku=64104
Coolermaster Hyper 212 Evo @ $28 (pricematch with http://www.directcanada.com/products/?sku=11130AC0554 )
http://ncix.com/products/?sku=64385
Bitfenix Shinobi @ $60
http://www.ncix.com/products/?sku=62891&promoid=1130
Western Digital Caviar Green 1.5TB @ $90
http://ncix.com/products/?sku=48813&promoid=1141
Crucial M4 128gb @ $185
http://www.ncix.com/products/?sku=60445&promoid=1130
DVD Burner @ $18
http://ncix.com/products/?sku=65984&promoid=1141
Windows 7 Home Premium x64 @ $98 (pricematch with http://www.hltechnology.com/one_prod.php?pid=209982 )
http://ncix.com/products/?sku=45271
Any feedbacks appreciated. thanks
Related ressources
@realtalk,
good selection.i would suggest these changes-
don't get the 'k' version if you don't want to overclock.i5 2400 is hardly 10~12% slower than 2500.save your bucks and go with 2400.it's a very good cpu.
that motherboard is not great.M-ATX mobos suck IMO.go with asrock extrme3/gen3.it''s cheap and good performer.
http://ncix.com/products/?sku=63945&vpn=Z68%20Extreme3%...
it has pci-e 3,usb 3 and all other 'required' things.
get this PSU-
http://www.ncix.com/products/?sku=59616&vpn=P1650SNLB9&...
it has more power and it also receives high ratings on johnyguru.
hyper 212 EVO is a great cooler but only if you want to go 4Ghz or more.you are new to overclocking.your best bet is to get a silent and cheap cooler.here's one-
http://ncix.com/products/?sku=67721&vpn=CNPS%205X%20Per...
HDD prices are high ATM.better you go with a green 500GB drive.
i own that SSD and it's great.but i would suggest going with mushkin cronos cause read/write speeds are better and mushkin is a reputed brand.get 120GB drive.8GB is not worth more bucks.here you go-
http://www.ncix.com/products/?sku=62873&vpn=MKNSSDCR120...
your case is good IMO.this one is better-
http://www.ncix.com/products/?sku=55583&vpn=RC-912-KKN1...
try to use the saved money to get a better gpu.a 6950 or 560ti will do fine.
hellfire24 said:
@realtalk,
get this PSU-
I'll definitely second the case and PSU choices here but I'd still stick with the Evo. IMO Zalman is kind of overrated for the fans they produce. You can't attach a second fan and the heat sinks tend to collect a lot of dust after long periods of time.
hellfire24 said:
hey g-unit,may be you are right.how about hyper tx3?
Not a bad choice but I personally find fans that use rubber connectors and cheap metal clips instead of the plastic rails to be the biggest pain to install, mounting fans on the Hyper 212 is one of the easiest I've ever worked with. I'm not gonna say I'm a total CM fanboy but this is one of the best coolers I've ever used and I've used everything from single one-fan solutions like the Zalman 9500 to huge multi-heat sinks like the Thermalright Silver Arrow. I haven't tried a closed block like the H100 yet but I'm certainly open to it.
I have my Hyper 212 with two fans running and my CPU idles at 21'C and doesn't get above 30'C on full use.
Final build thoughts ? I'm ordering the parts as soon as i get good reviews. Thx a lot guys.
ASRock Z68 EXTREME3 GEN3 ATX LGA1155 DDR3 2PCI-E16 2PCI-E SATA3 USB3.0 SLI CrossFireX Motherboard
http://www.ncix.com/products/index.php?sku=63945
Intel Core i5 2500K Quad Core Unlocked Processor LGA1155 3.3GHZ Sandy Bridge 6MB
http://www.ncix.com/products/index.php?sku=57962&promoi...
Mushkin Enhanced Silverline Stiletto 8GB 2X4GB PC3-10666 DDR3-1333 9-9-9-24 Dual Channel Memory Kit
http://www.ncix.com/products/index.php?sku=55544&promoi...
Samsung SH-222BB 22X DVD Writer SATA Black OEM
http://www.ncix.com/products/index.php?sku=65984&promoi...
Mushkin Chronos 120GB 2.5IN SATA3 Sandforce SF-2281 SSD Solid State Disk Flash Drive
http://www.ncix.com/products/index.php?sku=62873&promoi...
XFX Radeon HD 6970 2GB GDDR5 PCI-E 2XDVI HDMI 2x Mini DisplayPort Video Card
http://www.ncix.com/products/index.php?sku=57629&promoi...
Coolermaster Haf 912 Black Mid Tower ATX Case 4X5.25 1X3.5 6X3.5INT No PS Front USB Sound
http://www.ncix.com/products/index.php?sku=55583&promoi...
Coolermaster Hyper 212 Evo Direct Touch 4 Heatpipe Heatsink AM2 AM3 LGA1366 LGA1155 LGA1156 120MM
http://www.ncix.com/products/index.php?sku=64385&promoi...
Western Digital WD Caviar Green 500GB SATA3 7200RPM Intellipower 32MB 3.5IN Internal Hard Drive
http://www.ncix.com/products/index.php?sku=67463&promoi...
Microsoft Windows 7 Home Premium Edition 64BIT SP1 DVD OEM
http://www.ncix.com/products/index.php?sku=45271&promoi...
I took a more powerful powersupply cause i upgraded the gpu..
Any thoughts.
Really appreciated guys
yeah that's right IMO.6950 and 560ti are great value.if you can wait 7950(most probably under 400 and maybe less :)  )it will give gtx 580 class performance and definitely better than 6970 or 570.
Ask the community
