Yesterday, I tried to boot into Windows 7 and it wouldn't boot, giving me an error about nvlddkm.sys, which appears to be related to NVIDIA drivers. Safe mode worked, so I uninstalled the NVIDIA drivers then booted back into normal Windows and reinstalled it. After restarting to complete the driver installation, the computer went back to bluescreening. I decided to install Ubuntu at that point, and the install worked just fine. After installing, however, my computer would not boot into Ubuntu, either. Occasionally it worked, but on the whole it wouldn't work, crashing right before the login screen. I decided to switch back to Windows at that point, doing a fresh install. I just finished installing Windows, and I began to install a couple of programs, including the NVIDIA drivers. The computer then bluescreened when I tried to boot next. This is quite clearly a hardware problem, but I want to isolate it rather than RMAing likely culprits. In the past, my computer would freeze up occasionally but a reinstall seemed to fix that. I have run memtest on multiple occasions, with no errors found. My specs, if it helps:
Intel i7 930
2TB Hitatchi Deskstar
Coolermaster Fan (not sure which model, I can check if it makes a difference)
Geforce GTX 470
Corsair 750W PSU
Asus P6X58D Premium Motherboard
6GB G-Skill RAM
Creative SB Audigy Sound Card
Anyone have any ideas how I can isolate the problem? Thanks for your help.
Intel i7 930
Geforce GTX 470
Corsair 750W PSU
6GB G-Skill RAM
