Hi, i've bought all brand new components and built my computer from scratch.
i use genuine windows 7 ultimate 32bit
Been sitting here for 3 days and cant figure out the problem, build over 20 computers in my days and never encountered this before, maybe a component doesnt match the others or perhaps someone is broken altho its brand new.
the problem is that i after ive installed windows and downloaded all the drivers from my hardware websites it usually takes 10-15 mins then the computer screen gets black and stays that .. never returns
when i try to reset it i have to reset it atleast 4-5 times before i even can get into windows sometimes i have to reinstall windows.
ASUS own temp sensors shows the CPU / motherboard temp is around 30 celcius but a program i use often called Speccy (www.piriform.com) shows that the motherboard temp is around 82-88 celcius.
the components are: (And remember everything is connected properly and is all brand new)
Motherboard: ASUS P8H61-V (Socket 1155) (PCI-E 2.0 x16) (DDR3)
Graphics: Gainward Geforce GTX 560 Ti 1024mb (PCI-E 2.0 x16)
Processor: Intel i5 Qcore 3.1Ghz 1155
RAM: 2x2MB DDR3
Power: 500w Coolermaster.
2x 120mm fans , (1 from the side and 1 from the top + 1 chassi fan to take the warm air out.
please please help me, my brain is stuck...
RAM: 2x2MB DDR3
