Trying to hook up my old gaming pc. I vaguely remember that the XFX Gefore 9600 GSO card in the box had overheated when I used it last. Now when I power up with the 6-pin power connected to the card, the fans spin for a split second then die out. Turns on fine with the card in without it's power cord connected. I assume the card is dead, and just drawing power causing the PSU to give up. Is it worth it to spend 100$ on a new card, assuming that the old card is the problem? Thank you!
