Hello, I've had this computer for over a year and no problems at all. I put it together myself just buying all the parts in a bundle. It has a 250 gb Sata Hard drive, 450w power supply, and a Nvidia PCI* E graphics card and WinXP pro. It has been running smoothly for a very long time up until last week...
During a session of gaming my computer suddenly froze and I had to do a hard restart (power button). I've done this many times before, but this time, upon trying to boot up windows, this is what happens: I can hear the Hard drive spinning (like its trying to power up) than it stops, than it starts spinning again, than it stops, etc. than eventually I get the: 3rd master Hard Disk Error F1 to continue. I can get into Bios and it recognizes my CD-rom model, but not my HDD. It just says "hard drive" where it would usually say the model number. I have only 1 HDD.
Pri-master: Cd-rom
Pri-Slave: None
Sata 1: Hard Drive
Sata 2: none
boot sequence is HDD first, Cdrom second.
Here's what i tried so far:
-changed the sata cables
-tried a different sata slot
-changed cmos battery
-made sure no loose cables
If I am persistent enough, I can get windows to boot up and everything is normal, stable, and fast. But that's after many reboot attempts. Only problem is if I shut down and try to reboot, i get the same '3rd Master Hard disk Error'. Had me thinking, if its my HDD, than how come i can get into windows (after many tries). Maybe its power?
As for power supply; kinda has a noisy fan, but it quiets down after my computer has been running.
Thanks for any help.
*im going to replace my power or hdd soon, but can only afford one at this time. which one should i try first?
Pri-master: Cd-rom
Pri-Slave: None
Sata 1: Hard Drive
Sata 2: none
