I will be ordering my parts for my second build soon and I intend on modding a few things, but there are a few things I'm worried about.
For my build I will be painting the case and many other things and doing all sorts of stuff to make my build unique and because I have a colour scheme I really like.
There are a lot of things I want to do but there are only a few things I'm worried about that could alter the performance and cooling of my build.
1. If I were to put the fan on my CPU cooler to match the colour scheme is there a chance that the paint could unbalance the fan and make it rattle or not as effective. If it won't, what is the best method of doing this?
2. I want to paint the heatsink on my RAM and the heatsink found on the motherboard for the chipsets to make it fit my colour scheme, will the paint alter the cooling? And is there a certain paint I should use?
3. I'll paint the motherboard tray in my case and probably several other sections, will the paint effect the cooling of the case? And is there a certain paint I should use to least effect the cooling?
Thanks A lot!
Thanks A lot!
