Help help
Last response: in Systems
hi,i have a rig with a fx 8150 and 6970 i tried to see its value on newegg and its $900-1000 how much can i sell it for used??
More about : help
Since you have not listed every item brand, model number, age and condition it is very hard to figure what you have. However a general rule I figure to resell a brand new system just bought say with in 30 days, it would be worth no more than 75% of what was paid for it. I would never pay more than 40%-60% of the original cost of the parts for used. If it was branded (ie. HP, Dell, etc.) maybe even less as most box units are old before you get them. Systems from builders like Origin or I Buy Power have more value.
Related ressources
- INTEL overclocking guide - Forum
- http://www.tomshardware.com/forum/ [...] es#t599635 - Forum
- http://www.tomshardware.com/forum/ [...] rare-found - Forum
For starters most people who know about pcs generally do not like the new amd bulldozer chips as even the older phenom II chips out perform them. And that will hurt the price considerably. Unless you can find some one who doesn't know alot about them to sell it to i think you'd have to take a huge hit in its value to get some one even interested to be honest.
http://www.tomshardware.com/forum/103004-8-intel-2500k-...
considering that even though that bare bones kit (that you called terrible btw) is a better cpu and is only 429.99 i doubt you'd find many buyers willing to shell out much money for it. Unless like i said you find some one that knows little about cpus.
Based on your $1000 base price I think it is worth about $600-$700 to the right person. Probably less. It does not have the most desirable components and it is used. Sadly if you wait to sell it for another few months, it will be worth less and newer products come to market. Used systems like this are just not worth the trouble. The buyer will also be faced with having to transfer validations, registrations, user accounts and more to make it their own.
angaddev said:
it is terrible
Not when you consider that newegg is sold out at the moment of i5 2500k's
(also on a side note you should add a few amd build options in your build guide for amd fans) I like that option though if i had the money i'd pounce on it lol i could have a great pc to use while i save up to upgrade to a better motherboard psu video card and alot of ram. Its light years above my current set up of an athlon x2 4400+ using on board geforce 6100 on board graphics.
lol microcenters are nice if you live near one and a few amd phenom gaming builds wouldn't hurt for low budget gamers (you won't get the best possible performance but they aren't to shabby) and most amd phenom builds would come in under the 800.00 mark with a good monitor graphics card os and mouse and keyboard. Sorry for going way off topic >_<
take a look, http://www.tomshardware.com/reviews/gaming-fx-pentium-a...
Pentium is .2 FPS off the high-end Phenom and it's only $80
Rofl I can't knock my current system while its 6 years old i haven't found a game yet i can't play lol although i'd probably have a much better and easier time with a graphics card instead of my on board one. oh there is one city of heroes but thats because of my graphics card not because of my cpu. Cost wise amd is awesome but not always the best performance i'm hoping the piledriver chip gives amd fans a good alternative to intel but i'm not holding my breath after the bulldozer fiasco >_<
angaddev said:
take a look, http://www.tomshardware.com/reviews/gaming-fx-pentium-a...Pentium is .2 FPS off the high-end Phenom and it's only $80
True but that is the phenom x4 not the x6
biostar 6100-939 athlon 64x2 4400+ sadly my pci express is a 1.0a biostar told me a 2.1 would work nicely (i emailed them about my board) But for 6 years of being on almost 24/7 365 days i can not complain my only issue that has ever shown up is my monitor goes black for a few seconds randomly and i've deduced that it is my northbridge on my mother board getting hot and doing it at times. I'm planning on getting a new card to at the least fix my monitor going black. But gonna plan to doa new build after 6 years i feel its time lol
you could try this
CPU : Intel Core i3-2100 Sandy Bridge 3.1GHz LGA 1155 65W Dual-Core Desktop Processor BX80623I32100 $115
http://www.newegg.com/Product/Prod [...] 6819115078
Motherboard : ASRock P67 PRO3 SE LGA 1155 Intel P67
http://www.newegg.com/Product/Prod [...] 6813157249
RAM: Patriot Signature 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory $34.99
http://www.newegg.com/Product/Prod [...] 6820220570
CPU Cooler : COOLER MASTER Hyper 212 Plus $30
http://www.newegg.com/Product/Prod [...] 6835103065
HDD : Seagate Barracuda ST500DM002 500GB 7200 RPM 16MB Cache SATA 6.0Gb/s 3.5" Internal Hard Drive $85
http://www.newegg.com/Product/Prod [...] 6822148767
PSU : Antec EarthWatts Green EA-430D Green 430W Continuous power ATX12V v2.3 / EPS 12V 80 PLUS BRONZE Certified Active PFC Power Supply $60
http://www.newegg.com/Product/Prod [...] 6817371034
GPU : XFX HD-667X-ZNFQ Radeon HD 6670 1GB 128-bit DDR3 PCI Express 2.1 x16 HDCP Ready Video Card $75
http://www.newegg.com/Product/Prod [...] 6814150576
Case : Rosewill CHALLENGER Black Gaming ATX Mid Tower Computer Case, comes with Three Fans $55
http://www.newegg.com/Product/Prod [...] 6811147153
My cash flow will only allow me maybe 100.00 a month for each component max so gonna budget it later going to get the wife a pc first so we are not sharing so much and if i do i can use my old case but i'd rather just do a whole new build from the ground up. And in my price range probably going to be an amd phenom type build. When intel launch their new line i'm hoping to maybe catch a cheap i3 or i5 but i figure motherboard and cpu will be my last purchases in my build to allow for a price drop when the new chips come out. You can bet i'll be posting around then looking for the best deals i can get lol
Dogsnake said:
All this is way off topic. Please start a new thread.Check out the op's posts in other areas he was hoping to come here to offload a build pc thinking he would make money on it he has posted buying pc's as well as selling. I think he is just trying to use the forums to turn a profit. And his posts alone make me leery of him. No offence but by his posts i would think he is out to scam. An exampile? Strange new rare cpu!!! http://www.tomshardware.com/forum/318738-28-strange-rar... Personally i think he is more crooked then a dog wood tree but you are right we are way off topic.
In technical terms he hasn't broken any straight rules i know of. I assume that they are clear in the terms that any buying or selling is on the 2 people involved so even if he is scamming as i suspect i don't see how he'd get in trouble for it do you? Another posted topic of his that made me roll on the floor laughing Buying gaming rigs post offers buying 30!!!! http://www.tomshardware.com/forum/102944-8-buying-gamin... /shakeshead
http://www.tomshardware.com/forum/99995-8-read-first
And i quote
Violations - It violates the Tom's Hardware Rules of Conduct if you engage in any of the following activity:
Post, promote or distribute any content that is illegal.
Promote or encourage activity which is illegal, such as hacking, cracking, scamming.
So i guess it is in the rules but can you see any where specific that he has scammed so far? If i had i'd report it as i'm sure others would the 2 topics i posted here he has made come close but not a clear scam that i know of as of yet (no one he has scammed has came forward yet) Now back on topic
I seriously doubt that he can get much for this rig as most of the cheaper builds far surpass it. Even being an amd fan and having the money it would cost to put together its just not viably worth it in terms of costs and performance. To get half his money back he'd have to be very lucky.
And i quote
HAHAHA followed the other threads. Ok so here we have a guy who says he has a shop but builds and sells only as sort of a hobby but he charges people for his hobby work. He is so advanced in his abilities and knowledge that he needs public help forums to get information. Just the guy I would trust to sell or trade me anything.
Related ressources:
- Forumhttp://www.tomshardware.com/forum/ [...] ers-buying
- Forumhttp://www.tomshardware.com/forum/99995-8-read-first
- ForumBuilding a budget PC.
- ForumPlease Help with $2350 build here are my thoughts
- Forum[Solved] Can you help me with my first builds
- Forum[Solved] $1000 Gaming build- First timer please help.
- ForumBuilding a comp (Help needed)
- Forum[Solved] Need help on mobo, cpu, and ram.
- ForumHelp value of rig??
- ForumIm looking of advice on a custom build pc Please help :)
- ForumNeed Pro`s Help!Building $1200 Gaming Beast?
- Forum[Solved] [Please Help] Which mother board Should I get?
- More resources
