First Time Build - Need Help Checking Components Work Together
Hello,
I'm looking to build a computer since the one a friend built for me in college has finally died. This is my first build and I was hoping I could get some help confirming that the components that I had picked out would work together. I was hoping to reuse the case and power supply from my existing computer and just change out the rest. Thanks in advance for any help.
I've got an Antec case SLK2650-BQE and an AGI power supply API5PC17
The components I've picked out:
ASUS M4A87T motherboard
AMD Athlon II X4 645 Propus processor (ADX645WFGMBOX)
Galaxy GeForce GT 430 Fermi video card (43GGS8HX3SPZ)
G.Skill Value Series RAM (F3-10666CL9D-8GBNT)
Seagate Barracuda 500GB hard drive (ST500DM002)
ASUS DRW-24B1ST/BLK/B/AS DVD burner
2 answers Last reply
More about first time build checking components work together
  1. First fill this out and we can better assist you: http://www.tomshardware.com/forum/261222-31-build-advice
    I had that motherboard and it was pretty decent until it died.
    The GTX430 is very underpowered if you have any sort of gaming in mind.
  2. Ok, here is a little more information that you asked about.
    Approximate Purchase Date: as soon as I can get pieces picked out that I know will work together
    Budget Range: $450 after rebates
    System Usage from Most to Least Important: surfing the internet, music, gaming (really only play the Civ series anymore), movies
    Parts Not Required: keyboard, mouse, monitor, speakers, OS, case (Antec SLK2650-BQE), power supply (AGI API5PC17)
    Preferred Website(s) for Parts: newegg.com (open to other sites, this is just the only one I've used before for parts)
    Country: United States
    Parts Preferences: I had an AMD processor, GeForce video card, and ASUS motherboard in current build and was very happy with them and would like to use the same brands again
    Overclocking: No
    SLI or Crossfire: NO
    Monitor Resolution: 1920x1080
    Additional Comments: I'm slightly concerned that my existing power supply isn't enough for the new build. I tried looking at different places for power consumption info and got different results where some said I was fine and others said I was way over.
Homebuilt Build Components Systems
