I have a question I have been racking my brain about for a month and no one can help me elsewhere.
I am going to buy this computer: http://www.ebay.com/itm/Gateway-E-4610S-Desktop-PC-Computer-Intel-Core-2-Duo-E6600-2-4GHz-/170715618269?pt=Desktop_PCs&hash=item27bf719bdd
background on it: http://support.gateway.com/s/PC/E4610/1009365/1009365nv.shtml
My main reason for getting it is to play a game called Empire: Total War. Info/Requirements:
Minimum System Requirements
Supported OS: Windows® XP Service Pack 2 or Windows Vista™ or Windows 7™
Processor: 2.4 GHz Intel® Pentium® or greater or AMD® Athlon® equivalent CPU, with SSE2 instruction
Memory: 1 GB RAM (XP,) 2 GB RAM (Vista™)
Graphics: 100% DirectX 9.0c compatible hardware accelerated video card with shader version 2.0 support, 256 MB video memory
Display: Minimum screen resolution of 1024 x 768 pixels
Sound: Directx9.0c compatible sound card
Hard Drive: 15 GB free hard disk space formatted as NTFS
Peripherals: Windows compatible mouse and keyboard
Recommended Requirements
Processor: 2.4 GHz Intel® Core 2 Duo® or greater or AMD® Athlon64® equivalent CPU, with SSE2 instruction
Memory: 3 GB RAM (XP,) 4 GB RAM (Vista™)
Graphics: 100% DirectX 9.0c compatible hardware accelerated video card with shader version 3.0 support, 512 MB video memory
Display: Minimum screen resolution of 1280 x 1024 pixels
Getting to the point....I want to switch out the 128 MB card for a 512MB (if possible) but don't know much about video cards.
So my question is how good/what type of a video card can I get for that computer.
Thank you for your time.
