Estimated full load of rig is more than power supply..
Last response: in Components
I am looking to build a severely ridiculously powered computer. This is going to include 3 GTX 690 cards(overclocked), 2 3TB HDD, biggest SSD i can get, 3rd generation extreme i7 processor (going to be overclocked to hopefully around 4.8), a few bluray/dvd drives, 64 GB RAM, etc...
the point is, if i stress test my rig at full load to detect stability in my components, it will hit approximately 1550 watts. the PSU i plan to buy is only 1500 watts.
1. can i have all i mentioned in one PC(specifically THREE GTX 690's)?
2. will stress testing ever bring it up to maximum wattage in all the components?
3. if it does, what ae my option to increase PSU or decrease wattage usage?
More about : estimated full load rig power supply
Best solution
Looking at Anandtech's review, I see the GTX690 at 473W in Metro 2033. Be aware that this is TOTAL power consumption, including the i7@4.3GHz. So adding 2 more, it's less than 3*473W=1420W. Add your HDDs and whatever, you will not reach 1500W. Also, the 473W are the AC at wall, which includes the PSU efficiency, so with a 90% efficiency, I'm still talking about 425W.
Also, at least in gaming, I think one single card will be stressed more than having a 2nd card and doing more work per total. This is justified by the fact that 2 cards will never get 100% performance boost. The more units are added, the less the boost (so you 6 GPU setup will be pretty far from the 500% boost).
@ mathew7;
You didn't account for the 'etc...' in his build.
But you could be right and that would mean that joezeppy99 was wrong in his calculations that his system would draw 1550W DC.
I don't think joezeppy99 has realized yet the GTX 690s only have a single SLI tab and that he can't link his 3 GTX 690s together.
Related ressources
- New build -- Estimated 2,000 USD max - Forum
- Higher power supply wattage uses more electricity? - Forum
- 1st Rig Build : Vol: More for work than for fun. - Forum
- Photo / Full HD editing rig , $1,500 new build, feedback appreciated! - Forum
- Good card for my power supply - Forum
WR2 said:
@ mathew7;You didn't account for the 'etc...' in his build.
Lol yeah.
I know 3 GTX 690's will not SLI as 6 GPUs, but the first two will (4 GPUs).
1. What are the benefits and issues of adding the third card, even if it will not SLI (exclude financial reasons because it is not an issue)?
Under normal circumstances, the components should never get close to the maximum wattage (gaming). I am just concerned when I do the stress test when everything is overclocked (GPUs, memory, CPU) it will exceed the maximum rating of the PSU and rape my components. I do not worry about putting extra money into my rig to have better components, but I do have a problem with throwing money away to buy replacement parts.
So let's assume that everything is OCed as high as it can reasonably be (GPUs, memory, CPU) and assuming we have at least 4 fans, 3 HDDs, 1 SSD, 2-3 bluray drives, and liquid cooling.
2a. What are the wattages I should be looking at when idling?
2b. What are the wattages I should be looking at when under average load (gaming)?
2c. What are the wattages I should be looking at when under full load (stress testing)?
3. Based on your estimates, will a 1500 watt PSU be adequate for all situations in questions 2a-c?
(i know some of you responded already, but i wanted to cover my "etc..." in my post because it was causing a little confusion)
Finally, any suggestions on how to make my rig idea more powerful? budget= lol, what budget?
Remember that PSU's are typically, at best, 80% effecient. So a 1500W PSU will only typically deliver ~1200W. Heck, you might need a 1500W PSU JUST to power the GPU's...
Also, three 690's [heck, three of any GPU] is totally overkill and doesn't increase performance any. And the 64GB RAM is pointless given how 90% of apps are still coded as 32-bit EXEs, putting a hard limit of 4GB Address Space usage. Assuming you built this thing for gaming, about 56GB of RAM won't ever be used.
gamerk316 said:
Remember that PSU's are typically, at best, 80% effecient. So a 1500W PSU will only typically deliver ~1200W. Heck, you might need a 1500W PSU JUST to power the GPU's...So a PSU drawing 1500W DC @ 90% efficiency would draw 1650W from the AC wall socket.
1600w http://www.newegg.com/Product/Product.aspx?Item=N82E168...
Problem solved. Looks like you have a lot of money. How about just getting 2 power supplies?
Dual socket server board and a pair of 8 core Zeon's
Make a great folder with the 3 x 690's
I never liked the idea of using 2 PSUs, too many issues that a bigger PSU can easily solve.
Yes, I know 3 GTX 690s will not SLI together.
Your point? If I can drop $18,000 into a computer with a few monitors at the drop of a hat (which is what im doing), I'm not exactly worried about being "future-proof", although the server mobo with dual xeon's was a very fine idea.
You are partially right, I have money. I may not be an expert in computer building, but i do have enough sense to ask for help from experienced builders. The intention of this rig is primarily for gaming, but who wants a plain-jane gaming rig? I'm sure most of gamers would build a bigger and better rig if they could afford it.PS BTW you do not wanna hear about my server project build if you are bugging out about this rig.
Quote:
And you'll need to do it again in 2 years time when some guys £400 Dell beats it.Your point? If I can drop $18,000 into a computer with a few monitors at the drop of a hat (which is what im doing), I'm not exactly worried about being "future-proof", although the server mobo with dual xeon's was a very fine idea.
Quote:
Whats the point in this rig? If its for bragging it's an epic fail people will just think "fool with money.... all the gear NO idea"You are partially right, I have money. I may not be an expert in computer building, but i do have enough sense to ask for help from experienced builders. The intention of this rig is primarily for gaming, but who wants a plain-jane gaming rig? I'm sure most of gamers would build a bigger and better rig if they could afford it.PS BTW you do not wanna hear about my server project build if you are bugging out about this rig.
samuelspark said:
Why not save for a supercar?Agreed. If you have that much money, spend it on something people can actually see to "oohhh and ahhh" at and not something that will just sit there, in a case, that no one will ever see.
That's a little over the top, but I think you get my point. For a gaming rig, you're trying to spend WAY too much. Put your e-peen back in your pants.
joezeppy99 said:
1. supercars are nice, but spending 200k+ on a car is stupid. makes yourself a nice big target for problems of the criminal nature.2. I have a very nice 370z that I am very happy with, I do not need another fun car.
3. aside from PC's, im very conservative with what I have.
4. very off-topic, sir.
It's over the top, like I said, yes, but the point is, if you're only doing this to seem "cool" and rub it the face of everyone on the internet how "awesome" your rig is, you're way off base. If that really is the reason, get over yourself. No one cares. No gaming rig needs THREE GTX 690's (even if you COULD SLI all three). Just get two 690's. That is now, and will be for many years, ALL you will ever need.
Get a few of these and all your money goes away. Also, xeons are bad for gaming since games don't use more than 4 cores at once.
I would get an ivy bridge i7 and get liquid nitrogen for cooling if you want to waste money.
Why all the hate? If I had that kind of money I'd build some epic PC.
I think you can SLi 3 way 690s but It really isn't necessary, even if you literally had all the money in the world. 2 is awesome. If you want 64GB then go for it. I'd go for a 1600W or over PSU just to be safe and seeing as there is "no budget" you might as well.
samuelspark said:
http://www.newegg.com/Product/Product.aspx?Item=N82E168... Get a few of these and all your money goes away. Also, xeons are bad for gaming since games don't use more than 4 cores at once.
No, say it isn't so
Robi_g said:
Why all the hate? If I had that kind of money I'd build some epic PC.I think you can SLi 3 way 690s but It really isn't necessary, even if you literally had all the money in the world. 2 is awesome. If you want 64GB then go for it. I'd go for a 1600W or over PSU just to be safe and seeing as there is "no budget" you might as well.
You can't triple SLI 690's. Cus two GTX 690's is already quad sli 680's.
Related ressources:
- ForumNew machine shuts down under full load
- ForumNew estimate from computer guy, what do you think?
- ForumCant overclock 2500k more than 4ghz
- ForumIs this the correct estimated Wattage on pcpartpicker?
- ForumHow Redundant Power Supply power more than one server
- ForumSufficient Power Supply for this build?
- ForumDoes higher wattage power supply equal to a higher electricity drain?
- ForumI5-760~ 84 C full load prime95 stock cooler
- ForumNoob needs HD5870 power advice
- Forum2012 Gaming Rig - 2000$ budget / Please advice!
- ForumPossible power supply issue or something more ? please please help
- ForumHd 6770 atx 450w psu
- ForumCan this case and power supply support the Radeon 6870?
- Forum[Solved] Will this be able to power my computer?
- ForumWill LC power LC550 V2.2 PSU work with GTX 460?
- More resources
Read discussions in other Components categories
) replies. I think I found the answer I was looking for, much appreciated
