Solved
Case help? - USB 3.0 front, mid-tower, not mesh/vented all over
Hi all,
I'm building a system for my wife, and I would like it to be relatively quiet, which is why I don't want it to be all vented. It will go in an enclosure (open back, very airy) on the floor next to her desk, so I would like the front controls to be high on the front or top mounted.
Wish list:
- Stylish, but not flashy or weirdly shaped. Black is good.
- Ideally 2 x USB 3.0 and 2 x USB 2.0 front ports
- Controls, ports, etc are high up on the front panel, since it will be sitting below her desk.
- Minimum of mesh. I would like it quiet, and I believe that more mesh = less quiet.
- Good airflow given 2x"Gentle Typhoon" fans
- Good cable management
- Solid
- As cheap as possible ($75 or less)
Here is what is going into it:
Motherboard : Asus P8Z77-V ProP8Z77-V PRO LGA 1155 Z77 ATX Intel Motherboard
CPU : Intel Core i5-3570K Ivy Bridge 3.4GHz (3.8GHz Turbo) LGA 1155 77W - will prob do gentle overclock, if possible.
CPU Cooler: ZEROtherm Core92 CPU Cooler
Hard Drive: WD Caviar Black 1 TB SATA III 7200 RPM 64 MB - WD1002FAEX
HD Silencer: LOGISYS Computer HS102SL
RAM: G.SKILL Ares Series 16GB (4 x 4GB) DDR3 1866 Model F3-1866C9D-8GAB
SSD Cache Drive: OCZ Synapse Cache SYN-25SAT3-64G
Video Card: Gigabyte GV-R777OC-1GD 1024MB GDDR5 PCIe 3.0 x16
Power Supply: OCZ ModXStream Pro 600W
Fans: 2 x Scythe Gentle Typhoon D1225C12B5AP-15
Fan gaskets: 120mm Rubber Fan Silencer - I will also use rubber pins and/or grommets to mount the fans.
Thermal Paste: ARCTIC COOLING MX-2 Thermal Compound
Thanks in advance!
4 answers Last reply Best Answer
More about case help front tower mesh vented over
  1. Best answer
    That amount of USB ports is hard to meet..
    And don't worry about mesh so much, just turn the fans down to low.
    I have an antec 1200 http://store.antec.com/productimages/Originals/root/1200_front_q_lights.jpg
    All fans on low, barely hear it, and I have a cpu over clocked from 3.4 to 4.2 that never goes above 60c.
    Mesh: Not an issue.
    Case ideas:
    http://www.newegg.com/Product/Product.aspx?Item=N82E16811129181
    http://www.newegg.com/Product/Product.aspx?Item=N82E16811129183
  2. Thx and I now realize I was being a bit silly on the ports. I don't need quite so many because the asus mainboard has 4 USB 3.0 and 2 USB 2.0 in the back.
  3. I opted to go for this:
    LIAN LI PC-9F Black Aluminum ATX Mid Tower Computer Case
    http://www.newegg.com/Product/Product.aspx?Item=N82E16811112304
    because it looks good and for $72 with free shipping, its a steal.
    thanks!
  4. Best answer selected by MasonS.
Power Supplies Components Product
