Help me connect wired to internet
Alright. Just got a Used computer from a friend who reformatted it to brand new settings and I am trying to connect it to my Modem/router wired to the ethernet cable.
It isnt recognizing anything and it has something to do with the settings on the computer and the IP address on the computer and the router maybe. If someone can give me a step by step on how to get my newly formatted computer to even start recognizing my wired connection that would be great. It seems to be an on board ethernet hookup. Does this even work? or do I need a network adapter card for the computer. Basically my question is. How do I get a newly formatted computer to become internet ready on a completely different modem router setup
10 answers Last reply
More about help connect wired internet
  1. Hi perplexityx.....a perplexing puzzle for us :)
    Just a quick answer down 1 line only....... the set-up should be automatic under windows (7 ?), so I'm wondering if your router is separate from the modem. If yes then disconnect and bypass the router and see if this helps - if you need a password, windows should prompt you for one. Your friend had no probs with internet? you are plugging ethernet into ' active' port at back of computer - if >1 port try others - could be as simple as that.
    Alright I tried bypassing the router and it still didnt help. there is only 1 plug in the back for the ethernet cord. It doesnt even seem to be trying to pick up the signal. I looked on my old computer and it says there is a network adapter and on the new one I am not seeing any of that. unless im looking into something not even messing up the problem
  3. Are the drivers for the NIC installed? Check Device Manager and see if there is a NIC listed.
    I dont see one listed. im assuming one wouldnt be listed if its not installed. is that normal?
    the Mobo is a Gigabyte z68x -UD3-83 and yes its windows 7
  5. would I download the Lan drivers from this website that match my MoBo?
    http://www.gigabyte.com/products/product-page.aspx?pid=3978&dl=1#driver
    can I put them on a USB and then do it from my new computer?
  6. Yeah, it should be listed under Network Adapters if it's installed. Go to Gigabyte's support page for that mobo and get the NIC driver from there.
  7. many newer mboards have the nic built in, in which case, a simple download of the drivers might be all that's needed (though if that was the case you may see an issue/culprit flagged in device manager)
  8. This is the one you need, I believe. http://www.gigabyte.com/products/product-page.aspx?pid=3850#ov
    And yes, just put them on a USB.
    so should everything do its thing after i get this drivers? unfortunatlly i have to go buy a usb, but after this should everything just go step by step?
    It SHOULD, yes.
Connection Computers Components
