I recently bought a bundle deal from Newegg that comes with a fairly decent gaming setup. Everything seems to run normal, no crashes or conflicts, but when I try and play a game like Fallout New Vegas, it becomes unplayable as soon as there are more than 8 characters in the surrounding area and is generally "laggy" anyway.
Processor: AMD FX-6100 Zambezi 3.3 GHz Socket AM3+
Motherboard: Gigabyte GA-970A-D3 AM3+
GPU: GeForce GTX 560 Ti (Fermi) 1GB 256-bit GDDR5
RAM: G.SKILL Ripjaws Series 4GB (2 x 2GB) 240-Pin DDR3
HDD: Seagate Barracuda ST500DM002 500GB 7200RPM
OS: Windows 7 Home x64bit
I did a clean reinstall of my graphics card, and the issue is still there even with all graphical settings set to low. So I'm not sure if it is an issue with the motherboard/processor or what. Also my videocard was apparently manufactured by gigabyte. (Side note, I just recently installed the new beta driver from NVidia, 295.51, and it's the same problem. I have not tried rolling back my driver to something before 285.xx.)
Somewhere I read something that the motherboard doesn't draw enough voltage and can effect performance. I am not sure how to correct that issue. So anyway, my question is... what do I try next to get my computer running the way it should?
