Power Supply
Hey i couldnt find a thread specific to power supplies so i hope its ok to post this here. Im on a budget and will probably in the future post what im getting exactly for further help but right now im deciding what power supply i need. I plan on getting a i5 2500k or i5 2500/Something around that area of processors. I also plan to get a Gtx 660 when it comes out.
If i did overclock itd be miner.
What power supply do i need??
3 answers Last reply
More about power supply
  1. Use this calculator to get a general idea of the wattage.
    http://www.thermaltake.outervision.com/
  2. A build with a GTX 660 level graphics card will be fine with a quality 500w power supply. If you plan on upgrading to a high end card then 550 watts would be recommended. For 2 x cards in Sli 650-700 watts most likely. Here are some excellent 500w models.
    http://www.newegg.com/Product/Productcompare.aspx?Submit=ENE&N=100007657&IsNodeId=1&bop=And&ActiveSearchResult=True&CompareItemList=58%7C17%2D341%2D016%5E17%2D341%2D016%2DS01%23%2C17%2D371%2D035%5E17%2D371%2D035%2DTS%2C17%2D703%2D035%5E17%2D703%2D035%2DTS%2C17%2D256%2D065%5E17%2D256%2D065%2DTS%2C17%2D139%2D033%5E17%2D139%2D033%2DTS
    For $59 after rebate and an additional 15% off that before May 21 I would get the Seasonic made PC Power and Cooling Silencer MK III. A great unit for cheap and it's modular.
Power Supplies Intel i5 Components Product
