Hello,
I am currently using a Coolermaster V6 cooler for my processor, but the fan has died. What is the best fan that will fit this cooler (I assume all 120mm fans will?)? I am looking for one that is as quiet as possible, but has at least the performance of the stock fan that came with the V6. I believe it was 800-2200 RPM, PWM. I don't care about LEDs but if the best option does come with LED's I'd prefer blue. I don't care if it's necessarily a Coolermaster brand replacement fan, just whichever will be compatible and offer the best performance and is the quietest.
Also, my cooler is the base V6, not the V6GT which I think came with two fans. Should I get two fans, or will increase the noise a lot?
Thanks for any suggestions!
