Motherboard - msi p67a-g43
cpu - i5 2500k
case - nzxt phantom
psu - corsair 700w gaming
memory - 4x4gb patriot g2
Finally got everything running. Bios came right up and I started setting it up... and then noticed my cpu was running 90C and kept rising. Turned it off immediately when I saw that... getting a better cooler tomorrow and thermal compound. So hopefully that issue will be resolved.
The real problem though is that I'm using my hard drive from my old computer... It's SATA and not particularly old, but I did NOT format it because it had important files on it and I've no place to back them up atm. Will there be an issue loading up bios again after I hook up the new cooler and all that? I ask because I booted the pc for a moment to find out how it would load exactly and it just started up windows like with my old computer.
This is the last question I got. Appreciate all the help thus far!
cpu - i5 2500k
case - nzxt phantom
