Using Nikon Capture (for monochrome conversion)
Last response: in Digital Camera
Anonymous
May 20, 2005 5:19:24 PM
Archived from groups: rec.photo.digital (More info?)
I found the trial version of Photoshop Elements 3.0 very good for
converting images to monochrome, especially where you could desaturate
bands of colour to specific grey intensities. (I think it was in
colour level adjustment or something).
Is there such a capability in Nikon Capture?
I'm using its trial version now, to compare the two. I must say I
don't like Capture's histogram adjustment as much as in Photoshop's
raw import; having the lost high/lowlight onscreen at the same
time helps, and I haven't got the knack of the curve yet, but I
expect it might be more powerful than Photoshop's import tool.
Ken Tough
Anonymous
May 20, 2005 10:43:11 PM
On Fri, 20 May 2005 13:19:24 +0200, in rec.photo.digital Ken Tough
Not to my knowledge, but I don't do this.
FWIW, you can show lost shadows or highlights under the view menu..
Ed Ruf Lifetime AMA# 344007 (Usenet@EdwardG.Ruf.com)
See images taken with my CP-990/5700 & D70 at
http://edwardgruf.com/Digital_Photography/General/index...
May 21, 2005 2:24:38 AM
Here is what I do...I use Nikon Capture to convert it from the NEF file.
I adjust the white balance, do an initial contrast, and sometimes color
booster. Then I import into photoshop. Fine adjust the curves, and
saturation, then final step is Unsharp mask....I find the RAW conversion
in Nikon Capture is better than the Photoshop. It seems cleaner, plus
it starts you off with the camera presets....So the sharpness, white
balance, color mode, saturation from the in camera settings are the
defaults.
JR
Anonymous
May 21, 2005 1:43:40 PM
True, but you can't view both, with the image itself, as you
adjust the curve. (Or at least I can't seem to do it). You
have to keep flipping back & forth.
Ken Tough
Anonymous
May 21, 2005 8:26:06 PM
On Sat, 21 May 2005 09:43:40 +0200, in rec.photo.digital Ken Tough
True.
