Making a new thread for this because the old one is under graphics cards, and I don't think it belongs there. The old thread is here:
http://www.tomshardware.com/forum/341317-33-radeon-6950...
I'm getting frequent, random crashes on my new build. Sometimes it freezes at "Windows is starting," other times it crashes a few minutes into a session. Steps taken so far:
Updated the BIOS, because hey, why not.
At first I thought it might be the graphics card, so I removed that and tried booting up. Computer crashed at startup. Took the motherboard out of the case to rule out a short, and tried booting up with nothing attached except the RAM. This worked fine. Hooked up the hard drive (which was still mounted in the case) and tried booting again. This also worked fine - Windows started normally and everything. I installed 3DMark and PCMark from a USB drive, but didn't try to run either one because it was late in the day.
Next day: Installed the graphics card (motherboard is still sitting on the table at this point). Attempted to boot; crash on startup. Second attempt to boot got me into Windows, but the computer crashed a few minutes into PCMark. Removed the graphics card; successfully booted into Windows, but again, crashed a minute or so into PCMark. I had CoreTemp running, and it showed temperatures under 40 C the whole time. So yesterday, it appeared to work without the graphics card; today it doesn't. Must have been good/bad luck?
When it crashes, it crashes either right at startup (after POST), or less than five minutes after boot. Yesterday, I was puttering around on it for at least half an hour, and it was fine. Crashes don't just happen when I'm stressing the CPU; they also happen when I'm just using Firefox or something.
It's never crashed when I'm in the motherboard settings, but that could just be because it hasn't happened yet.
I've tried the sticks of memory separately and didn't see crashing, but I don't know if that's because the memory is fine, or just because it didn't crash THIS time.
Bad motherboard, bad PSU, bad CPU, bad memory, or some evil combination of the above? About all I can say right now is that it probably isn't the graphics card, since it crashes whether or not the card is installed, but of course I can't prove that the card isn't also damaged. Also, yesterday when it was miraculously crash-free, I ran disk check and it came up clean.
I've got no spare parts whatsoever, so I can't see if parts work in a different system or vice versa. I'm lost. Help?
Motherboard: ASRock Z68 Extreme3 Gen3
Graphics: AMD Radeon 6950 1 GB
Hard drive: Western Digital Caviar Black 500 GB
Memory: 2x GSkill 4GB Sniper Low Voltage Series
PSU: PC Power & Cooling Silencer Mk III 500W
Processor: Intel Core i5 2500K, not overclocked
OS: Windows 7 Professional
